Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 10-04-2003, 06:20 PM   #1
Tripp
Profile:
Images: 55
1973 Vista View Restoration
OK, finally got around to posting my vista view restoration. Sorry its been so long!!! (I've actually fixed several things, but this was the first I actually documented.)
I'm going to try to post the sequence of pictures. If they dont post, I'll try to describe the best I can.
This is the restoration of 1973 Vista View windows. Later models aren't as easy to fix.
First, remove the inner aluminum trim ring around the window using a small screw driver and hammer to "pop out" the ring. Start in the middle (at the seam) and work your way around the vista view. It will take some effort to get both sides out without damaging the inner plastic trim piece.
Tripp is offline   Reply With Quote
Old 10-04-2003, 08:41 PM   #2
Tripp
Profile:
Images: 55
OK, well. . . couldn't get the pictures to post, so here's the description. See my photo list for the pictures.
After you get the retaining ring out, use a small flat blade screwdriver to pop out the plexiglass inner pane. I didn't reinstall mine, so I just cleaned it and saved it for posterity.
Once the inner pane is out, get a helper to push on the outer pane from the outside of the trailer toward the inside. It will probably pop loose easily. If it doesn't, don't rush it! They are expensive! Once you have the pane loose, then pull it out (from the inside of the trailer). It may take a little persuasion to get past the plastic trim, but it will come out.
Take the outer pane to your workbench and clean it thoroughly. There is a mylar fim on the glass that may or may not be immediately apparent. Use a SHARP razor blade scraper to CAREFULLY remove the film. Once you have it off, clean the glass thoroughly. I used Barkeepers friend and a "white" scotchbrite scrubber (like you use on bathroom tile) to scrub the glass clean. The Barkeepers Friend doesn't scratch when used with the white pad.
Go back to the trailer and clean the frame for the window using laquer thinner or mineral spirits (same thing). Acetone evaporates too quickly to be of much use.
Once everything is spic and span, place a generous bead of Vulkem on the inside of the frame where the glass sits. pop in the glass.
IMPORTANT!! You will need some type of gasket to hold the glass against the frame of the trailer. I have been told that Vulkem will hold it by itself, but I used a 1/2" by 1/2" closed cell foam gasket with adhesive on one side and a urethane facing on the opposite side to add some insurance.
Apply the gasket with the adhesive toward the frame (90 degrees to the glass) so that the urethane facing will be visible once you have it all back together. (see pics)
Once the gasket is in place, reinstall the aluminum retaining ring (which will push the gasket against the glass and create a compression fit). Go to the outside of the trailer and wipe off the excess Vulkem. Be careful not to wipe away too much. It will shrink somewhat as it dries.
You want to leave a smooth bead to shed water over the outside frame of the window.
Add some new Vista View trim (available from Inland and others), crack open a cold one, and enjoy your "new", clear, and water tight windows!!
Tripp
Old 10-05-2003, 05:25 AM   #3
71tradewind
71tradewind's Avatar
Profile:
Tripp , great post thank you ! I am in the middle of doing this myself.
71tradewind is offline   Reply With Quote
Old 10-05-2003, 05:31 AM   #4
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
My '72 is a little different procedure. I used a Dremel tool, and more or less cut the plexiglass in half on the vertical plane. Then I took channel locks and broke pieces out, (wear goggles or safety glasses!!) until it was all removed. It really makes a mess. Keep a vacuum or shop vac handy during the process, especially when using a razor blade to scrape the 3M coating off of the inside of the remaining outer pane.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-05-2003, 03:05 PM   #5
71tradewind
Profile:
Pick , my "74" Tradewind is exactly the same as your photos show.My "71"Tradewind is completely different,they seem to only one payne of glass no plexi .I was wondering why did you decide not to put the plexi back in ,it seems that it would add to the insulating properties. Tom
vista view windows fundave For Sale & Wanted 1 12-02-2003 10:00 AM
Vista View Shade Replacemnt John Sims Upholstery, Blinds, Walls & Interior Finishes 2 09-07-2003 04:32 PM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 08:23 AM
Vista View Windows On 1979 31' Soverign montanaandy Windows & Screens 14 10-17-2002 05:03 PM
Vista view window repair/replacement 83Excella Windows & Screens 0 07-16-2002 09:46 PM
