Old 09-01-2011, 09:35 AM   #15
GlobeTrottin's Avatar
1964 19' Globetrotter
Chelsea , Michigan
I looked at the ways that are suggested above when the weld broke on my rear window while I was replacing the glass (with Lexan). All it took was one high speed baseball to shatter the original glass!
I tried using an L bracket made of aluminum but couldn't get it to tighten up using aluminum rivets.
Then I remembered that the West System G/Flex epoxy has very good aluminum adhesion properties. I roughed up the channel with 80 grit sandpaper and put in several layers of fiberglass embedded into the G/Flex. Looks and feels like it will never come apart in a million years, and the corner is permanently waterproof too!
ID:	139188   Click image for larger version
GlobeTrottin is offline   Reply With Quote
Old 09-05-2011, 08:18 PM   #16
1965 28' Ambassador
Malta , New York
glazing strips
am replacing the windows with new seal and glazing strips to hold the glass panes in place. I noticed one window along the top the glazing strip wont stay in place. doesn't lock in place like the others. any ideas?
Airstreamdmb is offline   Reply With Quote
'63 Sov-Hehr window replacement, help Dugger10 Windows & Screens 7 05-29-2009 05:16 PM
looking for a 1962 HEHR Side Window! A-Merry-Can Windows & Screens 4 07-02-2007 03:57 PM
Hehr window Judy Barde Windows & Screens 2 05-22-2007 06:39 PM
Fabrication of Hehr Street Side Window rek Windows & Screens 0 05-04-2007 01:12 PM
window broke, need advise on how to fix infinite LUX Our Community 4 08-03-2003 09:55 PM
