Old 11-19-2005, 07:06 AM   #1
1962 24' Tradewind
greensboro , North Carolina
will a '67 Tradewind door fit a '62 Tradewind?
Any of you guys know if a 67 tradewind entry door fit a 62, or could any 67 tradewind guys measure there door for me, take hinge pics etc. any help would be great.
Steve
scoxx30 is offline   Reply With Quote
Old 11-20-2005, 07:16 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
will a 67 trdewind door fit a 62 Tradewind?
Greetings Steve!
Steve
I can't give you a definite answer, but do know that there will be a significant difference in the hinges utilized. Your '62 would have had a "door-within-a-door" rather than the solid door with separate screen door that was utilized on the '67 -- the hinges utilized were quite different and there were likely some differences in the latching mechanisms as well.
Good luck with your research and search!
Kevin
Kevin D. Allen
AIR #827
Old 11-20-2005, 07:18 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The door itself will probably fit, but it will almost be more trouble than it is worth changing hinges, and latches, and maybe even the doorframe.
Old 11-21-2005, 09:53 AM   #4
1962 24' Tradewind
shoot!
thanks guys, if yall see a 62 door let me know.
Steve
Old 11-21-2005, 12:58 PM   #5
scoxx30
A 1967 door "will not" correct fot a 62.
The shape is different, the dimensions are different and the hinges are different.
Will a '71 screen door fit on a '68? moserj Doors & Locks 3 02-12-2015 02:00 PM
trying to remove - does bathtub section fit thru door groovzilla Sinks, Showers & Toilets 4 11-16-2013 06:23 AM
Exterior/Main Door Doesn't fit frame Angary Windows, Doors, Locks & Vents 1 11-13-2011 07:12 PM
Why doesn't this fit out the door? GR8DANE General Repair Forum 11 11-17-2008 07:29 AM
Entry door, what years fit? Toby Doors & Locks 4 09-16-2004 05:50 AM
