Old 08-02-2010, 06:22 PM   #1
1969 27' Overlander
Lehi , Utah
why doesn't my door close?
Every thing looks ok but the latch doesn't quite latch. I can't see how there is any way to adjust the hinge and the frame seems intact. any thoughts?
I have a 69 Overlander
Clay C
ClayC is offline   Reply With Quote
Old 08-02-2010, 06:32 PM   #2
judybug's Avatar
2004 25' Safari
san antonio , Texas
We have a 2004 Safari and had a problem with our latch not working properly. I made the mistake of using the stabilizing jacks to level the trailer. It caused the frame to bow just a bit and therefore the latch would not engage correctly. Now we use blocks under the wheels. Works better. This may not be your problem, but it's an easy place to start. Good luck.
judybug is offline   Reply With Quote
Old 08-03-2010, 02:41 AM   #3
1969 27' Overlander
Lehi , Utah
Thanks Judybug,
maybe i will try and tweak it a little with jacks maybe the frame has a problem.
Clay C
Old 08-03-2010, 06:27 AM   #4
richinny's Avatar
2011 34' Classic
i don't think you have jacks. stabilizers are NOT to be used to lift the trailer as they will bend the body. i believe they lift the body and not the frame.
Ricky
Old 08-03-2010, 06:51 AM   #5
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
What ever you do, DO NOT loosen the door hinges. Once loose, it is a real pain to retighten.
raveson is offline   Reply With Quote
Old 08-09-2010, 01:31 PM   #6
Clay C
Is the striker bolt and striker plate OK?
Old 08-10-2010, 08:46 PM   #7
1969 27' Overlander
Lehi , Utah
the plate is really worn maybe that is the problem
Clay
Old 08-10-2010, 09:14 PM   #8
Clay
For a 69 model, the striker plate is supposed to be a "nylon" striker pocket.
Old 08-11-2010, 09:37 AM   #9
1969 27' Overlander
Lehi , Utah
Mine is aluminum, maybe Its a different door than what came on it.
Old 08-11-2010, 10:47 AM   #10
The original 1969 door striker pocket was nylon.
A metal pocket was used starting in 1970.
Is there any "wear" on the striker bolt ?
The bolt and plate or pocket must be in good condition. If not, the door will not proper seal, when closed.
Door will not close anymore Lothlorian Doors & Locks 0 07-05-2010 05:37 PM
WANTED: beside the door handle for 1970 Overlander or close. bookman General Repair Forum 6 07-31-2008 07:58 AM
door out of alignment-won't close JimChandler Doors & Locks 4 03-22-2007 08:14 PM
Door won't close right andyfuson Jacks, Stabilizers, Lifting and Leveling 13 07-26-2006 08:18 AM
Shower door won't close Whistling_Gypsy General Interior Topics 0 12-30-2003 05:11 PM
