Old 08-08-2012, 04:19 AM   #1
1964 26' Overlander
Toronto , Ontario
Which lock for '64 Overlander?
I have an Overlander located in a remote part of Nova Scotia and I live 1000's of miles away! When I last was out there, I discovered that the lock set was broken. I ain't no expert on any of this stuff and I'm sure some of you would be appalled to know that my Airstream sits where it is exposed to gales, salty breezes and major winter blizzards.
Anyhow, here i am back at home and I am utterly confused by all this lock stuff. Does anyone know which set I should be looking for as a replacement? I believe it's the tumbler that is broken.
Here are a couple of pics.
Thanks!
Name:	the whole shebang.jpg
wigwag is offline   Reply With Quote
Old 08-08-2012, 04:27 AM   #2
1964 26' Overlander
Toronto , Ontario
PS I used to be registered on here as "surfscoter" but surprise, surprise, I forgot my password and so started over. I've had some really helpful advice from you all!
Old 10-25-2013, 06:15 AM   #3
1964 26' Overlander
lewisburg , West Virginia
Bump... an answer for the searchers.
A Bargman L-100 was on my '64 Overlander. It has the turn knobs on both sides. There is another identical lock (L-200) with the only difference I see = is a horizontal handle used on the inside.
I'm not impressed with the quality/ functionality of these locks., but for authenticity, they are what we originally had in '64. I added a modern deadbolt lock in the door below the Bargman for real security.
gumparker is offline   Reply With Quote
Old 10-25-2013, 07:42 AM   #4
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I ordered a new chrome door knob for mine from Vintage Trailer supply. It looks awesome, and it was an exact fit. Well, almost. The hole for the knob needed to be moved over toward the jamb by about 1/8". I used a 1" round sanding drum in my drill. I just moved it up and down in the hole and it worked perfectly.
Closes with barely a swing and holds the door shut.
I just ordered a deadbolt from this site, but that was yesterday, so I don't know if it will be the right fit. The measurements looked like they would work.
http://www.doorcorner.com/depochsicyde.html?utm_source=googlepepla&utm_mediu m=adwords&id=20005783933&utm_content=pla&gclid=CL7 DiPXKxrkCFRQOOgodwRcAwA#sthash.LGwZveJV.5UbCEzec.d pbs
robwok is offline   Reply With Quote
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Xena Lock With Alarm For Hitch Coupler wjk Hitches, Couplers & Balls 8 04-13-2011 06:27 AM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
