Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 05-23-2006, 08:04 AM   #1
Profile:  1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Where is a good place to get hardware?
My mom does not know where my father left the keys to the out side acces doors I have a key to main door but it will not fit outside access doors so I need new ones the two battery doors are lever key operated the others are push lock and twist types anyone know where I can find them?
Mrcrowley is offline   Reply With Quote
Old 05-23-2006, 08:56 AM   #2
Profile:  1975 29' Ambassador
Reno , Nevada
Find a friend with an Airstream as much like yours as possible and borrow his key. The key you are looking for is probably a generic 1101X and the same key is used on nearly all of the exterior access doors for this era Airstreams.
The water and battery keys are sometimes outliers, though. But again, a friend with a similar trailer probably has a key that will work.
Newer ones often use a CH751. Sometimes your local hardware or RV place might have these.
Old 05-23-2006, 06:58 PM   #3
Images: 33
Well I had to drill out the battery box locks BUT?
I want new anyways. So you say a trailer dealer would have them are they pretty universal the locks? I really am not looking to keep trailer original just function this trailer is great shape I want use it no restore it.
Old 05-23-2006, 07:34 PM   #4
GO Bob's Avatar
Profile:  1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
I believe the water key for '70s are the same. Check with other owners of those years in your area. My lock on my water door was froze on my '82. I drilled it out and still trying to get it out. Last resort!!!!! I have replaced my battery door locks. Got them from a local SOB dealer.
GO Bob is offline   Reply With Quote
Old 05-23-2006, 07:41 PM   #5
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Mrcrowley,
I had my local locksmith make a key for the water fill door. It took him only 15 minutes.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 05-24-2006, 09:40 AM   #6
Images: 33
Originally Posted by wkerfoot
Mrcrowley,
Bill
Hey wkerfoot about how much was it to get a key made and will the key work on other access door locks.
thanks
Old 05-24-2006, 10:21 AM   #7
wkerfoot's Avatar
1954 29' Liner
Orange , California
thanks
Mrcrowley,
I don't remember, it was almost four years ago. It was very reasonable and I had some duplicates keys made also, probably less than $50. I needed the key made because the water fill door key was different than the battery and storage compartment doors. I have two keys for the four doors.
Bill
Old 05-27-2006, 02:30 AM   #8
Images: 33
Found keys thank god after I drilled out battery box key latches but I think I can get those easy enough any one know what size the one for the battery box is ? AND where I can get one ?
tow cars Cruiser Tow Vehicles 38 10-30-2003 01:58 PM
Sliding Cabinet Hardware LKappenman Cabinets, Counter Tops & Furnishings 5 10-20-2002 04:53 PM
Brakes good enough? Jabba Brakes & Brake Controllers 7 10-14-2002 03:43 PM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 01:08 PM
Good campground in Omaha NE area? 83Excella On The Road... 0 07-24-2002 09:01 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
