Old 11-09-2003, 02:53 PM   #1
aviontt's Avatar
, Connecticut
Where can you get 'em
I need an outside door lock and handle for my 74 Argosy......Where could I find one?
aviontt is offline   Reply With Quote
Old 11-09-2003, 03:18 PM   #2
Chas's Avatar
Images: 22
Maybe you should be asking, 'Where can I find one cheap?"
You will be much better off trying to repair it as a new lock is right around $500!!
I kid you not.
Chas
Chas is offline   Reply With Quote
Old 11-09-2003, 03:26 PM   #3
aviontt's Avatar
, Connecticut
This guy has been replaced once already so I don't think the parts are Airstream.
Old 11-09-2003, 03:28 PM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
That's an Airstream lock alright. I replaced the same on on my 77, back in 95, then the lock was "only" $295.00
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 11-09-2003, 03:31 PM   #5
aviontt's Avatar
, Connecticut
On the inside of the lock it has a tag from an aftermarket MFG..? Could it be a good clone..... Maybe a Dead bolt kit is in order any Ideas on this?
Old 11-09-2003, 06:19 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Believe they were made by Bargman, at one point in time. That is the same lock I have on my 71. I was looking at an Argosy where the lock was heavily damaged, I was quoted somewhere in the $350 range for a new lock assembly. The one I have is in ok shape. I am going to have my friendly locksmith (not the clueless itdiots at the local home center) see what can be done to refurbish it, replace pins springs, keyways and the like. BTW what is wrong with yours?
Aaron
Old 11-09-2003, 06:22 PM   #7
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
If it is just a matter of the key not working the tumbler can be replaced for less than 20 bucks.
A deadbolt can be added but requires some modifications to the bolt to minimize the hole in the door frames. A standard hole will leave you with on frame left
The lock was made for Airstream by a 3rd party. At this time I believe the only way to get one is to get a rebuild and they are not cheap. There is a way to retrofit a current style lock in the door, but a filler plate is required and it will not look good unless you are ready to paint.
Brett G
Old 11-09-2003, 06:33 PM   #8
aviontt's Avatar
, Connecticut
Parts missing inside on lock pivot arm.. so the door wont lock BTW this is not a Bargman it's a gypsy...looks just like one though...
Old 11-09-2003, 07:04 PM   #9
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The door would not open. That was 3 units ago............. As far as I know it is still working fine.
Brett G
Old 11-09-2003, 09:32 PM   #10
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Thumbs up I fixed mine
I got parts for mine at www.oasisrv.com.
It's not cheap but it can be done. I paid $30 for the thumb screw that lets you lock it from the inside.
I also paid about $25 for a new lock cylinder and keys.
It can be repaired and Oasis has the stuff.
Good luck!
-Tim
theVAP - Airstream Podcast
Bad swivel light ball & socket Rick T Electrical - Systems, Generators, Batteries & Solar 12 05-15-2005 07:47 PM
Canton, Texas Trade Days Feb 27-28 87MH Forum Rallies & Meet Ups 27 03-16-2004 11:00 AM
How Do You Keep Em From Stealing It judge3rd Our Community 33 11-23-2003 01:25 PM
Stripping...Clearcoat that is! InsideOut Cleaning, Stripping & Polishing 19 07-12-2003 07:59 PM
Water heater bypass installation Craig Water Heaters, Filters & Pumps 4 04-05-2003 04:13 PM
