Old 04-24-2003, 09:38 PM   #1
tiniree's Avatar
Question What type of door lock after '77?
I have read several posts here about the KT door lock and how expensive it is to replace. However, the AS we are looking at is a 1978 and on one of the posts I read AS only used the KT up until 1977.
What type of door lock did they use after 1977? Would the door lock for a 1978 be easier to replace and less costly?
tiniree is offline   Reply With Quote
Old 04-25-2003, 09:59 AM   #2
Door locks
The expensive "KT" lock was used from 1970 to 1977.
Keeler Brass was used from 1978 to 1987.
The Keeler Brass became no longer available, It was replaced with a "GM" lock, that also required an adapter plate.
Next in line, the "GM" lock also became no longer available.
The next replacement, and still continues that way, is a "Tri-marK" lock, along with an adapter plate.
It does require a small modification to the door.
Currently, the tri-mark fits 1978 to 1991 trailers.
If someone does not want to modify the door, they just simply are out of luck.
The lock for the motorhomes is an Bargman L-300. The door must be modified. Again, if someone does not want to modify the door, they are out of luck. Takes aboiut 3 hours for the motorhomes.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 04-25-2003, 10:13 AM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Question Whatever happened to
Andy,
Excuse me for the interrupution but...
Whatever happened to the concept of; Making "spares for a certain number of years"???
I know ..it cost money but..What the heck?
"People will/do break door lock~!~"
I'm in no way, taking it out on you...Just sharing a thought~
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is online now   Reply With Quote
Old 04-25-2003, 10:26 AM   #4
tiniree's Avatar
Ok, Tri-mark for the 1978 with door modification. What type of modification? Will the original screen door still fit after the modification? How much currently are the Tri-Mark locks?
Old 04-25-2003, 11:01 AM   #5
Airstream makes trailers and motorhomes, not locks.
They try very hard to use components that will be around for a long time, but, they don't have a crystal ball.
So that forces everyone to go to the next best thing.
Modifying the door requires new holes in the side of the door frame.
There is nothing that gets in the way of the screen door.
There are 6 different items that make up the Tri-mark kit, 10 parts in all.
The complete kit costs $139.00.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 04-25-2003, 11:11 AM   #6
tiniree's Avatar
Thanks for the quick answer, Andy!
As a footnote: I can't help but see several people "surprised" at the cost of parts. Yes, some are expensive. We haven't even picked up our AS yet and are prepared to "pay the price of ownership". With all the change-overs going on with major corporations today, I expect half the "logos" on most of the stuff I buy today to have changed in the next 25 years!
From a womans perspective: Husbands ask your wives how many times they have had to change bra brands because from one year to the next the company "changed" their styles, colors, etc..... We woman are used to and expect change!
Old 04-25-2003, 11:47 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you can get a tumbler made by Keeler that fits the old Bargman lock. It is 15 dollars and available in many RV parts locations, if this link works, its where I got mine.
http://www.rvlifestyles.net/catalog/...X0110152734187
Old 08-08-2003, 06:38 AM   #8
1986 31' Sovereign
Lenox , Georgia
I just went through changing.......
out the door lock on my 1986 31' Sovereign. I couldn't find a used original for under $500. Reluctantly, I went the Tri-Mark route, and am satisfied. I ordered it from Andy at Inland RV at a cost of $154.00 including shipping costs. A local established locksmith had it retro-fitted within an hour. He put a stainless steel back-plate on both the interior and exterior. It looks fine and operates well. It did not effect the original screen door.
joe hall is offline   Reply With Quote
Old 09-18-2003, 02:52 PM   #9
WBCCI 11067 WDCU
ckeysor's Avatar
1986 25' Sovereign
Atlanta , Georgia
Images: 30
I recently retrofitted my lock kit also on my 1978 Ambassodor. I did it myself (on a trip) and found it to be relatively easy.
I am amazed at the difference in quality between new and old. I hate replacing that good old stuff!
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 08-30-2004, 10:02 AM   #10
I have a 1960 Airstream Pacer which has the Bargman L 77 door lock. Do you know if the Keeler cylinder will replace the cylinder in this lock? Thanks for any help you may be able to give me.
Cazadero is offline   Reply With Quote
Old 08-30-2004, 11:14 AM   #11
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Not really sure on yours, but I found the part easily at a local RV supply store, you could compare them side by side if you pull the old one.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-30-2004, 11:58 AM   #12
Smile
Thanks I'll get one and try it. I had a locksmith in New Mexico try to repair the old one but he broke it and didn't return the pieces.
Old 08-30-2004, 12:09 PM   #13
Images: 59
The locksmith that re-keyed my Bargman L-77 called it a 'Ford' cylinder. He didn't have any problems working on it.
markdoane is online now   Reply With Quote
Old 08-30-2004, 04:37 PM   #14
Thanks--for the info. If I can't get a Bargman replacement I'll try the Ford replacement. I read somewhere that the Ford cylinder is from the mid fifties and is called a Hurd cylinder.
my '77 land yacht w/o brakes wayne.yl Brakes & Brake Controllers 20 12-26-2003 06:55 PM
Front console for a 77 Argosy saxonsraven Our Community 6 06-23-2003 08:46 PM
Tube type tires for 77 alum rims Mike B Tires 10 04-09-2003 08:04 PM
What type of battery should we get? Anna Electrical - Systems, Generators, Batteries & Solar 3 11-26-2002 10:23 AM
What Type of Polishing Pad to Use? 68 Suburban Cleaning, Stripping & Polishing 0 10-22-2002 02:28 PM
