Old 08-30-2004, 04:46 PM   #15
Images: 59
If you look at this site, about half way down (PN 1343380 or 1360839) you will find a Hurd cylinder that looks like a replacement. http://www.studebakerclubs.com/stelf...osedBodies.htm
Thanks for the tip. Easy to find if you know the name!
markdoane is online now   Reply With Quote
Old 08-30-2004, 05:11 PM   #16
Don--Not having seen the cylinder out of the lock, I didn't know what it would look like. My understanding was the Hurd was used in the Studebaker until the late forties and went to Ford in the fifties. Thanks
Cazadero is offline   Reply With Quote
Old 08-30-2004, 05:39 PM   #17
Images: 59
It looks just like the one I totally disassembled. I was lucky to get enough of the little springs and buttons back in it to give the locksmith something to work with.
You might want to order one, be sure you can return it if it's not right.
Or better yet,l take it to a different locksmith. I think if you give him the mfg name he should be able to order parts.
Old 08-30-2004, 05:42 PM   #18
Thanks-- I'll do that. I feel like pretty sure I'll find the right parts. Thanks for your help.
Old 08-30-2004, 07:24 PM   #19
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
as Andy stated if you want a working lock you will have to go the replacement route. i had my lock destroyed when a drugie thought he could get into my motor home. i lucked out on my lock. i found a locksmith with a complete lock. he had it for a long time and he was happy to sell me the lock. i was darn happy to buy it. the drugie relocated to Ohio before i could get a piece of his zw8x.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 08-30-2004, 09:12 PM   #20
RivetED's Avatar
North Central , USA
Originally Posted by tiniree
Thanks for the quick answer, Andy!
...With all the change-overs going on with major corporations today, I expect half the "logos" on most of the stuff I buy today to have changed in the next 25 years!
I retired from Digital Equipment Corp (DEC), Compaq sent me checks for a while and now they come from H-P!! As long as they still come...
RivetED is offline   Reply With Quote
Old 09-14-2005, 03:39 PM   #21
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
A source for the L-77 lock cylinder
I just ran across this ad for a company that claims to have the L-77 lock cylinder for $3.60 and thought I'd pass it on to those in search of same.
http://www.nwlock.com/products_i1549...ml?catId=70792
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 02-03-2009, 10:23 AM   #22
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
Lightbulb Vintage Trailer Locks
Here's a page I put together to help everyone identify their locks. It is a work in progress, but it should help. Some of these were never used on Airstreams...
https://www.vintagetrailersupply.com...les.asp?ID=155
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Old 02-03-2009, 01:45 PM   #23
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Steve, Thanks for the breakdown on the locks and when they became obsolete. I have an Avion that uses that first L-400 lock. I was able to find parts for it about a year ago. Some long time RV dealers have old stock on the shelves, Some dealers trash it and write it off when it fails to sell after a certain time period.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 02-03-2009, 01:50 PM   #24
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Thanks Steve
I now know my Lock is a KT but U didn't indicate if its obsolete or not.
Thanks for the time U spent putting that together
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 02-03-2009, 01:57 PM   #25
Originally Posted by Mikethefixit View Post
Thanks Steve
The KT locks were used from 1970 thru and including 1977 modesl.
They are still available new.
Repair parts for them are not cheap, but they are available.
A new KT lock from Airstream uses a little bit different tumbler. That tumbler will not fit the original KT locks. We had some tumblers modified to work with the orignal KT's.
From the 78 models to about 84, Airstream used a Keeler Brass lock. It's and parts for it, are no longer available.
Then in about 85 Airstream went to a GM lock, (not general motors). They made adapter plates so you could replace the obsolete Keeler Brass lock.
Old 09-15-2009, 03:55 PM   #26
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
Just in case anybody stumbles across this thread..
We have a '79, and had no keys. This part right here fit perfectly, took about 20 minutes. Now have a proper, factory lock.
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 09-21-2009, 09:49 AM   #27
VintageRV's Avatar
1956 22' Caravanner
That's a key and cylinder for a Keeler Brass Company (KBC) lock (vertical lock orientation). That cylinder is available from most RV dealers. The cylinder for the old KT locks (horizontal lock orientation) is not available.
Steve Hingtgen
WBCCI #1573
my '77 land yacht w/o brakes wayne.yl Brakes & Brake Controllers 20 12-26-2003 06:55 PM
Front console for a 77 Argosy saxonsraven Our Community 6 06-23-2003 08:46 PM
Tube type tires for 77 alum rims Mike B Tires 10 04-09-2003 08:04 PM
What type of battery should we get? Anna Electrical - Systems, Generators, Batteries & Solar 3 11-26-2002 10:23 AM
What Type of Polishing Pad to Use? 68 Suburban Cleaning, Stripping & Polishing 0 10-22-2002 02:28 PM
