Old 05-23-2008, 03:06 PM   #1
magna1111's Avatar
1978 31' Excella 500
Eureka , California
What is this missing door handle called?
This is my first post on this forum, I live in Northern CA. (anyone from around here?)
I just bought my second POwned Airstream, it is a 78 31'. I have the floor ripped out, installing floating floor I learn about from these forums. Fixing dry rot, from learning on these forums, and bought the blue stripping from Inland RV supply.
Could someone help me with what this missing door handle is called? It is to the right of the sprung (another topic) door, and appears to have had a key lock at the top, as there is a "deadbolt" thingy that turns on the interior. TY all, and I can not get the search working on this forum--I bought gutter seal, and other caulks recommened here--and cant find the links that said what to use on which area...
Umm, uploaded pics, and they say they are here....in my upload folder...I hope they show up when I submit..
I just want to sound like I know what I may be talking about when I call dealers to replace the missing handle. Illusion is everything.
ID:	60888   Click image for larger version
magna1111 is offline   Reply With Quote
Old 05-23-2008, 03:53 PM   #2
Retired.
. , At Large
Welcome tot he forums. The missing handle is what I call a grab handle. It should be around a foot long, and is mounted vertically next to the door.
Old 05-23-2008, 04:09 PM   #3
That part is called a "grab bar" with a lock.
Airstream discontinued using it, many years ago.
Back then, when it was last available, it cost almost $400.00.
You can use a regular grab bar.
Your other photo, if I am correct is for the left side of the A-frame.
If that's the case, you need far more than just Vulkem sealer. That separation is caused by punishing the front end, buy having a heavy duty tow vehicle, and/or hitch bars that are for the Queen Mary.
The front end is being torn apart, when you tow the trailer, because of the stiffness of the tow vehicle and/or excessive rated hitch bars.
You will have to soften that rigging if you want to stop the front end from getting destroyed.
Andey
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-23-2008, 04:50 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Related Question
Andey
Hi Andy,
I have a question related to the “grab bar.” How do you change the doorbell button? Do you just pry it out from the front?
Vaughan
Old 05-23-2008, 05:02 PM   #5
Originally Posted by vswingfield
Hi Andy,
Pry it out gently.
It's just a press fit.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-23-2008, 05:03 PM   #6
1983 34' Excella
1967 24' Tradewind
Images: 32
Thanks Andy,
That's what it looked like, but why experiment when you can ask?
Vaughan
Old 05-23-2008, 05:34 PM   #7
Thanks Andy,
Er, umm, that's what my old girl friend used to say.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-23-2008, 05:41 PM   #8
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Andy must be feeling much better!
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-23-2008, 05:46 PM   #9
Yep. Feeling better.
Will be out of pocket for a week.
Will be visiting parts of North Carolina.
Wish everyone a safe and happy Memorial Day.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-23-2008, 07:05 PM   #10
Retired.
. , At Large
For the inserted caption in your second picture, you should use Vulkem (aka protrem) to seal the gap after you get the "beating" taken care of.
Old 05-23-2008, 10:57 PM   #11
magna1111's Avatar
Eureka , California
Ok, wow, the PO owner gave me all the towing gear
When you say softer gear...do you mean lighter hitch? It is really heavy. Or, perhaps the stiff rectangular bar that attaches from the hitch to truck on the street side.
The Truck that pulls it, is a 78 huge Scottsdale pu, 2 wheel, C10, 4 door. Any tips of how to lighten it all up? I plan to pull it 4 hours, then hopefully never again. The truck gets 7 miles to the gallon. It came with the trailer.
I have seen photos of cadillacs pulling them, do all vehicles have to get special rigging (hydrolic air system) to operate the disk brakes on the trailer?? Otherwise I could pull it with my Chevy Van perhaps.
Old 05-24-2008, 02:30 AM   #12
NevadaGeo's Avatar
Genoa , Nevada
Wow, you cheated the "how do I hook up the vacuum disc brake" process and got an old tow vehicle with vacuum! A lot of us don't have a ready source of vacuum on our truck, so we got an electric "activator" that pressurizes the hydraulic disc brakes. Does your vacuum brake boost system work on that '78?
NevadaGeo is offline   Reply With Quote
Old 05-24-2008, 07:01 AM   #13
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
TV Overkill
Andey
I have been wondering the same thing. I am towing my Tradewind with a F250. There is no damage to my AS, and it tows fine on all paved roads and most dirt. But, I tried a couple of times pulling down some New Mexico washboard roads and it seemed the coach rode much better than the TV in which I felt every bump. Looking in my rearview the AS was nice and level and not jumping around. But the rough ride must be transmitted at least to the trailer tongue. Cqn't be a good thing. I turned around as soon as I could. Maybe a lighter sprung TV and a lighter foot would be more comfortable for the AS and the riders in the TV.
Old 05-24-2008, 08:47 AM   #14
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Airstream Funeral Coach
Citrus Heights , California
Images: 35
Grab bar
Here's mine on the Excella. I've noticed the same thing on a few Moho's.You don't have a spare door lock do you?
Name:	86 Excella.jpg
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 05-29-2008, 10:32 AM   #15
magna1111's Avatar
Eureka , California
doorgunner, that looks like what i am missing
I assume my tv came with the vaccumm thing, as that is what the owners said, and there is a sealing type of pressure lock that attaches the tv to the airstream.
Sure could use that lock doorgunner, pass it on when you are done with it!
I just put a new floor in the trailer this weekend... used ideas from this forum, got the armstrong tack type of floor that is floating, and glues to itself. It looks good. I will post pics, but I think it has to be in the flooring forum.
Thanks all for replying, I am pulling her for the first time on the 23 rd of June, up to Hornbrook Ca from Eureka. Not too much punishment, she has been all over mexico with the po's.
Wish me luck, never pulled anything that big before, plus I will have 5 kids with me...
Before I head out, I am attempting to reseal all the seams etc. Trying to figure out all the caulking is rather confusing. Even on the airstream site, they have a picutre of vulcum, when you click on it, the picture changes to silkflex, and the text description uses tem pro 635, gosh 3 products in one...check it out for fun.... https://store.airstream.com/product_...roducts_id=162
Old 05-29-2008, 10:44 AM   #16
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
They are all the same product.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 06-02-2008, 11:38 AM   #17
magna1111's Avatar
Eureka , California
Thanks for the photo doorgunner
Thats the handle, I am trying to find it so it can temp, solve my door not closing problem. I think the dead bolt part will hold the door shut.
Unable to find one yet,
be different, be daring, go natural
https://www.itssimplynatural.com
Old 06-02-2008, 11:56 AM   #18
That lock was a replacement for the Keeler Brass lock, made by GM, (not general motors).
However it has not been available for several years.
We have a replacement for both those locks.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-02-2008, 12:10 PM   #19
magna1111's Avatar
Eureka , California
Andy, when I placed my order last week....
Your nice person said she was the only one working that day, and would ask about that part when others returned, I just did not know what part number to use. Ok, now that you have it, I will call back and try to explain it again to the person that answers.
Ty
Door Handle - Replacement for 1981 Excella dienst1 General Motorhome Topics 44 10-08-2011 10:36 PM
door handle Richard Murphy Doors & Locks 10 09-27-2004 10:54 AM
Missing cabinet door dmadam Cabinets, Counter Tops & Furnishings 7 03-19-2004 11:46 AM
