06-26-2015, 03:37 PM
Spring
What is this and what does it do???
Can someone please tell me what this is, attached to the door and what it is suppose to do??
Outside on the door
Inside on the door
06-26-2015, 03:46 PM
Chief Ding Dong
1966 28' Ambassador
Patterson
, Louisiana
Homemade deadbolt?
06-26-2015, 03:48 PM
1967 22' Safari
MILAN
Well....
I would guess it might be some sort of dead bolt lock. Check the door frame edge for any hint of a bolt pocket or door edge for bolt itself. Or It may be just a door buzzer. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
06-26-2015, 03:59 PM
???????? well you have me curious
Judging by the screws, it is most likely an aftermarket modification.
Perhaps part of a system to prevent the door from opening while in transit. If a door does open while moving, the wind can slam the door open, and cause damage.
Perhaps part of a system to keep the door open while camping.
Have you checked the side edge of the door for a dead bolt. It could be a homemade lock. ( Conventional store bought dead bolts are a chore to install)
To be honest….I don't know what it is…….but I really want one
06-26-2015, 04:07 PM
Spring
I thought it was a dead bolt as well, but there is nothing in the frame or the edge of the door.
It has screws on both sides.
And what I would think as something to move a lever is on the outside of the door.
I don't see anything for it to attach to, if the door is open or closed. And it is such a heavy piece.
I tried to turn it by putting a screwdriver through what I figured was a moveable part. And I couldn't get it to budge.
06-26-2015, 04:23 PM
Biloxi
, Mississippi
Could you possible take another outside picture showing more of the door and side. Hard to tell anything from the limited area shown.
MICHAEL
06-26-2015, 04:26 PM
Lin
, Ne
You will have to take it off to see what it is.
06-26-2015, 04:41 PM
It coulda happened that way
Let's just say the previous owner had a dog. The said owner slept au natural. The dog liked to " water " the lawn, at precisely 45 seconds past bedtime. The then naked previous owner could attach the leash AND unattach the leash to retrieve the dog without advertising his " shortcomings " to any pain in the neck innocent bystanders.
06-26-2015, 04:43 PM
Mantua
, Ohio
How high up on the door is it?
06-26-2015, 05:06 PM
Spring
Yes I will. First thing in the morning.
Thanks for the help
06-26-2015, 05:12 PM
Spring
Now that gave me a huge smile and made me laugh.
If this is the case...... wonder how well it will work with the 5 dogs we have?
06-26-2015, 05:14 PM
Spring
I am not sure. But will find out when I get more pictures tomorrow.
06-26-2015, 05:17 PM
Spring
Love it......
06-27-2015, 07:58 AM
Hmmmmm
I don't think you need to take it off to see what it is. It's a nut and bolt. The only thing that is not visible is some threads.
DAVID LETTERMAN TOP TEN OPTIONS
#1 Keep it as a conversation piece.
#2 Lie……Tell people it is to attach a flux capacitor
#3 Use the hole to install a door bell
#4 Find the previous owner and ask him or her
#5 Use it to hang a do not disturb sign
#6 Lock a spare key to it.
#7 Attach fishing line and a pulley system for practical jokes
#8 Use the hole to install a peep hole
#9 Install a fake gun barrel to it.
#10 Fagedda bout it
06-27-2015, 08:05 AM
This is still bugging me
Do you have a handle next to the door to help you get up into the trailer. Mine does. When my lock broke I used it ( in a pinch, just to get on the road) to secure the door in transit. Could this mod be a way to tie the door to the handle.
06-27-2015, 01:24 PM
2012 23' FB International
Woodstock
, Ontario
looks like a place to attach a dog tether to me!
JCW
06-27-2015, 02:35 PM
1978 28' Ambassador
Morada
I dont know what it is, but it's sure ugly..! Sorry, couldn"t resist....
06-27-2015, 02:48 PM
Spring
Pictures
06-27-2015, 03:09 PM
Spring
Yes......yes it is.......
06-27-2015, 05:08 PM
Slowpoke
2012 27' Flying Cloud
Portland
, Oregon
So, I'm guessing you slid a screwdriver through the hole in the stud on the outside. Correct?
And the stud wouldn't turn. Correct?
Have you tried loosening the big nut behind the stud? If not, loosen it and see if the stud will turn.
The big nut on the inside looks like it might be a cap. Have you tried removing it?
Just a couple of idle thoughts. I really have no idea what the thing is.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
