Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 03-03-2004, 07:18 AM   #1
Profile:
weatherstripping around the door
Where can I get the replacement weatherstripping to go around the door of my 1971 Land Yacht?
carolynwestern is offline   Reply With Quote
Old 03-03-2004, 07:37 AM   #2
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Dealership
If you are a purist, most any Airstream dealer,
If not purist but want it to work well,
Home depot, Weather stripping.
Hard part is getting the old stuff off.
I am certain a dealer will chime in and tell you horror stories of not keeping it pure
Smily
smily is offline   Reply With Quote
Old 03-03-2004, 08:24 AM   #3
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Fit and function
I'll admit I'm a purist, but not to a fault. Don't tell anyone, but I used a different style wire cap when I replaced my backup light sockets
I don't know if your '71 door seal is the same as the one on my '67, but on mine, the seal is not made of foam like the stuff sold at home improvement centers. As a consequence, it lays flatter. As I understand it, the design of the seal incorporates a small flap which seals tighter when wind hits it.
A foam-type seal from a home improvement store may make your door harder to close if your original seal was thinner.
I got my all my seals from the friendly folks at InlandRV.com
Hope this helps,
Tom
Old 03-03-2004, 09:59 AM   #4
GA Airstreamer Air_005
ALANSD's Avatar
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
unless you are keeping your AS as a collectible, I would always use the best product I can find original or not. Certain Airstream specific items of course, excluded.
Often times it is the new version minor replacement parts that are better suited to the job on these older rigs.
I recall when I changed out my woodgrain stripe for a new look, I got a fair amount of good natured ( I hope) flack about it. But it sure did improve the look of my coach.
Rallys twice a year..Lots of fun, food, and aluminum.
http://airstreampassion.blogspot.com/
My Music Ministry Site:
HTTP://ALANDAVIDSONGS.COM
Old 03-03-2004, 10:07 AM   #5
Still Working
smily's Avatar
Foam sizes
You can buy several thicknesses of Weatherstripping at HD.
The contributor above is correct if you use stripping that is too thick it will hinder the door closing.
I think you can get weatherstrip as thin as .25 inches. I think if you look real hard you may even find some in white rather that black or grey.
How much did that OEM weatherstrip cost you at inland?
Smily
Old 03-03-2004, 10:34 AM   #6
TomW's Avatar
Re: Foam sizes
I paid $0.75 per foot (plus adhesive).
Here is Andy's picture of it. I repeat, "Andy's picture" - It is his, not mine:
http://www.inlandrv.com/parts/005s-gasket.jpg
To pre-empt the replies that are sure to follow, "Yes, it is more expensive than a foam gasket." But, since Airstream used foam gaskets on other parts of my Overlander, I decided they used this particular style of gasket on the door for a reason.
I will make a multitude of mistakes on my Overlander before its maiden voyage. I would like to think they will be out of ignorance, not arrogance that "I know better than Airstream (and my way was cheaper)".
Sorry, didn't mean to rant. As you can see below, there are plenty of areas waiting for mistakes to be made:
Old 03-03-2004, 10:46 AM   #7
Still Working
smily's Avatar
Experience
It was honest question on cost of gasket and I admire your purism, nothing wrong with that at all
I am not recommending either approach, merely pointing out some options.
Here is a little experience speaking on from both sides, professional advice and the final approach. make certain to read the whole thread
http://www.airforums.com/forum...t=door+gaskets
Smily
Old 07-23-2004, 02:47 PM   #8
DavidsonOverlander's Avatar
Profile:  1964 26' Overlander
Milton , ON
Which way does this weather striping go and how far from the edge of the door? I'm assuming that the fins slant toward the edge of the door - is that right? In cross section would it look like the picture that I've attached?
Grant
1964 Overlander
DavidsonOverlander is offline   Reply With Quote
Old 07-23-2004, 03:24 PM   #9
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
Almost right...we just replaced the gasket on our '64 GlobeTrotter this spring. The gasket actually goes on BOTH the FRAME and the DOOR on ours. (see sketch below) I can take a picture later this afternoon...
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 07-23-2004, 06:04 PM   #10
Milton , ON
Thanks Shari. When I ordered the weatherstrip from Inland I was told that it only went on the door and that I needed 16', which is about right to go around the door once. Should I have ordered 32'? The weather strip that was there was not original. There is an old gasket on the door frame like you show in your drawing, but I wasn't sure if it was original or not. It's more of a rounded shape, not the kind with the fins.
Grant
Old 07-23-2004, 06:07 PM   #11
Profile:  Corona , California
How much door gasket is needed depends on the year of the trailer, and on the type of gasket.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-23-2004, 06:41 PM   #12
Milton , ON
Thanks Andy. I have a 1964 Overlander. Am I okay with gasket only on the door, or should there also be gasket on the flange of the door jamb as shown in Shari's drawing? Is there a specific measurement from the edge of the door that the gasket should be?
Grant
Old 07-23-2004, 10:09 PM   #13
InsideOut's Avatar
1956 22' Safari
Images: 87
Airstream Registry
It's been raining all afternoon/evening...now it's dark. I'll get a picture posted tomorrow.
I don't mind the rain...we definately need it!!!
Shari
Old 07-24-2004, 10:02 AM   #14
Grant.
If done properly, the gasket is only needed on the door.
The gasket is installed next to the edge of the door.
Again, the flare must go outward, as Sheri has shown.
Andy Rogozinski
Inland RV Center
Corona, CA
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
