Old 09-01-2004, 07:58 PM   #1
2005 30' Safari
River Forest , Illinois
Water leak into trunk area
This has been driving me crazy trying to figure out. In my ’99 Safari 25, I have a water leak in the rear trunk area on the door side. It does not get soaked, but rather maintains a slight dampness to the carpet. I have checked the top lights, the side light and the rear light. They are sealed on the top, and open on the bottom. There is no indication of water through the lights. The trunk closes tightly, and everything on the roof looks sealed. This winter I had some work done – replaced the trunk latches and replace the bottom chrome trim. I suspect that one of the two must be my problem, but I cannot figure out a solution short of using gobs of sealant on both. Any suggestions?
Rick Gillis is offline   Reply With Quote
Old 09-01-2004, 08:31 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Is there enough room for you to climb in while someone wets the trailer down? That's how the dealers sometimes find the problems in this area.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-01-2004, 11:21 PM   #3
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Maybe you could put a bright light in the trunk and close the door and look for the light leaking thorugh. Of course you would do this at night.
I had to do this in my closet near the wet bath to finally find my leak there.
-Tim
theVAP - Airstream Podcast
Old 09-04-2004, 06:21 AM   #4
2005 30' Safari
Both are good ideas! I have twin 8 year olds that would love the opportunity to take turns locking each other in the trunk, and have Dad endorse the idea. I’ll start with the light, since the trailer is currently in storage without access to water.
Rick
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
water leak adolph Waste Systems, Tanks & Totes 7 08-11-2004 05:04 PM
intermittent water leak drcharles2 Plumbing - Systems & Fixtures 2 01-22-2004 10:32 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
