Old 08-01-2006, 09:22 AM   #1
Mudmuffin
1991 29' Excella
1993 30' Excella
Crossett , Arkansas
Warped door on my '91 Excella
The door on my airstream is slightly bowed (1/4 inch) out at the bottom front edge and does not seal completely. The hinges are functional. I talked to an AS service person who told me they correct this problem at his dealership as follows. Lock the door, have a helper hold the upper part of the door in its proper location, place a piece of 2x4 lumber accross the bottom 1/3 of the door and push hard. This bends the door into its orginal curved shape. They "fix them all of the time this way".
Has anyone heard or done this and did it work?
mudmuffin is offline   Reply With Quote
Old 08-01-2006, 09:33 AM   #2
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
No idea about this repair technique, but I was at Jackson Center yesterday and was talking to an elderly couple whose 2004 Safari door was struck in an RV parking lot by a Class C moho and the replacement cost was $3,000! It would have been $4,000 if the frame had been damaged. It might be worth taking it to the dealer and letting them try their "expert" hand at it rather than risking damaging it further yourself.
Family of Disney Fanatics
WBCCI# 4821
Old 08-01-2006, 11:29 AM   #3
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Yes, this is exactly how the door on my 93 Excella was fixed. Ours was warped more than yours too. We had the local dealer do the correction, was under $80.00 labor if I recall...
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 08-01-2006, 11:47 AM   #4
Mudmuffin
1991 29' Excella
1993 30' Excella
Crossett , Arkansas
Thanks Leon. Did you watch them do this? I was not sure as to the actual force required and potential damage to the outside of the door. I would take it to the dealer but that is several hours away. In explaining to the service rep he stated that I could do the same thing he would do at the shop and save the travel time and money. Charles @ MaryLynn
Old 08-01-2006, 11:53 AM   #5
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Mudmuffin, I have seen this done on "sprung" pickup truck doors and it worked well. Were I doing it, I would have the wife hold the 2 X 4 and just begin springing (pushing) the door lightly until it gradually moved back into position.
Good luck.
Greg
Roadtoaster is offline   Reply With Quote
Old 08-01-2006, 06:52 PM   #6
the ponz's Avatar
Detroit , Michigan
The door seal on my 1986 sovereing is in great shape. It was not, however, making a good seal with the coach near the top of the door and would allow rain water to leak in. I did in fact use the exact 2x4 method you descrided to adjust the door to fit properly. I discovered it was easier to have three people for the project: one to hold the lumber, one to push on the top of the door and one to push on the bottom of the door. If somewhat equal force was not applied to the top and the bottom of the door at the same time, I found the door had a tendancy to bow out at the bottom when I pushed on the top. Having someone push (or simply hold it in place) on the bottom as I applied force to the top worked much better than simply applying force on the top alone.
It has been two years since I put the wood to the door and it hasn't leaked since.
ponz
86' 31' Sovereign
the ponz is offline   Reply With Quote
Old 08-01-2006, 08:14 PM   #7
casarodante's Avatar
2012 31' Classic
Do you have pictures of this before? Ours is slightly out at the bottom so I have a vested interest in this.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 11-30-2012, 01:03 PM   #8
TPdrums's Avatar
1972 27' Overlander
Mo Hill , California
BUMP...
I have this very same problem, and I'm trying to figure out just what you are prying against. Where are you resting the 2x4..? Can someone post a quick pic?
I read in the manual, that it's best to remove the rivets around the perimeter, and then bend the door. Replacing the rivets and adding more to substantiate the change, and keep it from bending back.
Thanks for any helpful replies.
Fine Woodworking, Furniture, Carpentry, Drums, and Lutherie
www.ToddCreatedWood.com
http://toddcreatedwood.blogspot.com/
TPdrums is offline   Reply With Quote
Old 12-03-2012, 10:08 AM   #9
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Without endorsement because I haven't tried it, check out this video:
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 12-22-2012, 04:43 PM   #10
1993 29' Excella
Portland , Oregon
Funny, I just noticed today, before reading this post, that my door wasn't seating properly at the top. I just grabbed the top and twisted it a bit and voila!
OverToyed is offline   Reply With Quote
Old 12-28-2012, 05:54 PM   #11
TPdrums's Avatar
1972 27' Overlander
I ended up strategically placing a few pieces of hardwood, and a couple clamps. Then proceeded to press on the door in the right places to get a better seal. Had to check and bend a few times. It worked though, I just didn't think it would bend in quite the direction I was needing.
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 16 07-08-2012 11:05 PM
1988 Excella 32' GVWR Confusion! Rob&Julie Towing, Tow Vehicles & Hitches 26 03-17-2012 02:06 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
