Old 09-20-2010, 08:12 AM   #1
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Waiting to Escape.... , Somewhere between sanity and insanity ... on the brink of both.
Unlocked....
Hey All,
we've got ourselves a small problem with the door lock on our '71 overlander. Every time we depart we lock the door BUT by the time we arrive it's unlocked. It always stays shut but consistently comes unlocked. For instance, yesterday we pulled out of our weekend site and by the time we got to the exit to the RV park it was unlocked (less than 1/8 of a mile on smooth concrete). Any ideas?
Thanks!
Nicki
TAC OK-42
Come See Minnie Mouse at the TAC Walt Disney World Fort Wilderness Rally
http://airstreamingdreaming.blogspot.com
"Get busy livin', or get busy dyin'." - The Shawshank Redemption
rebelstand is offline   Reply With Quote
Old 09-20-2010, 08:19 AM   #2
Originally Posted by rebelstand View Post
Hey All,
Thanks!
Sounds like the small spring and steel ball are missing, which allows the locking pin to move as it wishes.
You must remove the lock to replace those parts.
They are located above the striker bolt.
Old 09-20-2010, 08:30 AM   #3
r carl's Avatar
Lin , Ne
Disassembly and inspection is in order.
Old 09-20-2010, 08:51 AM   #4
Kevin245's Avatar
For peace of mind you might want add door wedge to your travel kit just in the case one day the lock doesn't old while in transit.
Cry Me A River... Bent Door - Dented Side - Page 2 - Airstream Forums
Regards,
Kevin
Eleanor Roosevelt
Old 09-20-2010, 09:46 AM   #5
r carl's Avatar
Lin , Ne
Or a deadbolt if there is room.
Old 09-20-2010, 10:02 AM   #6
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Someone put a deadbolt on mine. Drilled into the frame and door. I posted pictures somewhere but cant find the tread sorry.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-20-2010, 10:29 AM   #7
AirConditioner's Avatar
bungee security
Hey All,
Thanks!
Andy nailed the 95 % probability problem. We use a small bungee cord from the hinges to the handle as a safety.
AirConditioner is offline   Reply With Quote
Old 09-20-2010, 10:33 AM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Regards,
Kevin
This won't work on a 71 (wish it would) the assist handle is enclosed...
Old 09-20-2010, 10:54 AM   #9
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
It looks like DH will be spending some time removing the lock soon. Thanks to everyone for the advice. Will let you know what we find out.
Nicki
TAC OK-42
Old 09-20-2010, 10:55 AM   #10
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
I know -- it kinda stinks...when my wife told me about that suggestion, I remembered the earlier "show your door wedge" post and I was somewhat envious. But alas, I supposed I'm just gonna have to take it apart -- has anyone actually done this? Is it relatively easy? Will I have to remove the skin from the interior part of the door?
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 09-20-2010, 11:15 AM   #11
You must remove a few of the rivets around the door lock, on the inside metal only.
That will allow you to remove the lock.
NEXT: USE CAUTION
There is an adjustment at the end of the lock, near the striker bolt. It's a recessed allen set screw. That loosens or tightens the spring pressure on the steel ball. Moving the locking pin will confirm that to you. If you remove that screw, the very small spring and steel ball will pop out when you least expect it. If it's not there, then that's why the locking pin will not stay in position.
Old 09-20-2010, 11:44 AM   #12
Kevin245's Avatar
Oh yes I forgot about the the bug scoop handles.
Eleanor Roosevelt
Old 09-25-2010, 09:41 AM   #13
Addicted
exthemius's Avatar
1971 27' Overlander
Images: 16
ID:	111600 Click image for larger version
Okay, so the lock is out, and fortunately (or unfortunately, depending on how you look at it) it is NOT the spring and bearing -- those are completely in place. I'm going to explain what is happening and then include some photos to see if there are any suggestions other than a complete replacement.
So there is a cylinder with a "cam" (can't think of anything else to call it) that sits inside of a rod/bolt with a notch or cutout in it. This bolt slides up and down either manually (via the knob on the inside of the door) or via turning the key. This bolt/rod also has two flares in it that line up with the spring and bearing, allowing it to "snap" into either the locked or unlocked state. This all works great when throwing it up or down with the inside knob.
However, when doing it via the key, the cam only pushes the bolt down halfway, and for whatever reason, it stay in this halfway state (meaning that it won't "snap" into that lower flare). At this point it does actually lock the door, but if you bump or hit the door (just a gentle knock on the lock itself) instead of falling down and snapping (which I wish it would) it instead pops up, unlocking it.
Any thoughts....detailed photos included.
Thanks in advance!
-Shawn
TAC OK-42
Old 09-25-2010, 10:10 AM   #14
Attachment 111600 Attachment 111601
Thanks in advance!
Quite well the pin on the back side of the tumbler is worn.
Also, did you check the tension adjustment on the vertical locking shaft?
door, locks
