Old 08-05-2005, 01:19 PM   #1
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Travel Lock Woes
Today I took the Safari for some service and when I got there, the entrance door wouldn't open. After some fiddling I realized that the travel lock bolt had not pulled back even though I had thrown back the knob. After I got the door open by pushing the bolt back with a thin bladed screwdriver I discovered that bolt had come free of the lock mechanism. It won't retract now.
Actually the "bolt" looks more like a crush pin I believe it is called. Is this the correct configuration of the travel lock, and can it be fixed?
John
AYRSTRM2 is offline   Reply With Quote
Old 08-05-2005, 08:10 PM   #2
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Pix ?
AYRSTRM2,
Can you post a photo or two?
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 08-06-2005, 09:07 AM   #3
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
I will but there's not much to see, a small tube of metal and an empty hole. Do you have experience repairing the travel lock?
John
Old 08-16-2005, 03:08 PM   #4
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Again, if anyone has any info on problems with and fixing the travel lock/dead bolt, I'd appreciate hearing about it.
John
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Broken Travel Lock Charcigar Doors & Locks 2 06-08-2004 08:23 AM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
