Old 03-21-2009, 06:19 PM   #1
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
The tale of the walking door hinge pin
This is a pretty well documented issue here on the forums. My 01' Classic S/O has the problematic entry door lower hinge pin that walks upwards after driving about 100 miles. On our last trip i had to tap it down 3 times. So I first had new tires / drums balanced along with replacement 550lb load bars in case I was just beating it to death. These things made a difference but the pin will still work its way upwards. So i thought I would try to install a roll pin to the lower pivot of the bottom hinge.
I bought a few drill bits 3/32 (and i went through two) and began to drill out the lower hinge part that attaches to the door not the coach. The coach part pivots as it opens and closes and this would break the roll pin.
The pin is very hard material so take it slow so you dont break off the drill bit !
Once drilled and deep enough for the roll pin to be tapped in i sealed the opening of the pin with parbond. Hopefully this frustrating little problem is behind me.
Name:	door repair 002.jpg
ID:	77219   Click image for larger version
Name:	door repair 003.jpg
Name:	door repair 006.jpg
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 01-04-2015, 04:48 PM   #2
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Thanks.
-evan
eheffa is offline   Reply With Quote
Old 01-04-2015, 07:54 PM   #3
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Evan, I just took a small cold chisel and gently pushed the hinge material over the top of the pin. Worked fine. This was on a '98 Safari.
Old 01-04-2015, 08:18 PM   #4
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
New style pins have groove and a C clip between top and the next section of the hinge, works really well...
Old 01-04-2015, 08:25 PM   #5
moderator
Airslide's Avatar
Wilton , California
Images: 50
The new pins are the ticket... didn't have that option back in 2009. Im glad Airstream figured it out :-)
Door Hinge Pin Comes out 64Vette Doors & Locks 26 09-27-2007 04:34 PM
Door hinge pin? 65 overlander Doors & Locks 3 09-10-2005 01:04 AM
Top door hinge pin works out during travel? Kistler Our Community 4 06-20-2005 07:04 PM
door hinge worn not the pin silver 67 Doors & Locks 5 08-11-2004 08:30 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
