Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 10-26-2007, 11:21 AM   #1
2006 28' Safari
Rockport , Texas
That &^%$ Hinge Pin
I know this sounds like a trivial question, folks, but it's about to drive me up the wall!
We bought our 2006 28' Safari new in March 2006. We have spent eight months in it since then, and almost every day I've had to get out the hammer and bang the pin on the lower door hinge back into place. I've tried peening the aluminum on the hinge casting with a center punch; I've tried Loktite screw glue; I've taken it to the dealer who peened the casting with even more force than I had used. Nothing works. The trailer is still in warranty, but before I ask them just to replace the ^&*( hinge, I wonder if anyone has any suggestions.
Thanks!
jspeer is offline   Reply With Quote
Old 10-26-2007, 11:30 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Tell them to replace it. If you've tried all that other stuff, clearly the hole is too big or the pin is too small... (excise dirty joke here).
Old 10-26-2007, 11:43 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Drill a 1/16 dia hole through the hinge and pin and install a 1/16 roll pin through the whole assembly
Old 10-26-2007, 11:52 AM   #4
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
epoxy? Since it is still in warrenty have them replace it and find the root cause. it should not have failed that quickly.
Michelle TAC MT-0
Sarah, Snowball
Old 10-26-2007, 12:41 PM   #5
Thanks!
The most common cause of hinge pin displacement, is "lack of proper running gear balance."
Installing a roll pin thru the hinge pin will certainly stop it from coming out again, but that will not eliminate the need for proper running gear balance.
Loosening the hinge pin, is just one of many things vibration can effect.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-26-2007, 12:45 PM   #6
Auretrvr's Avatar
Iowa City , Iowa
Warranty Service would be the right choice...
...but in our case (1983 310 MH) we have to stick to home remedies!
I used loctite but first applied the ($15.00) anaerobic surface prep.
We haven't been on the road yet but will be going to southern Illinois and eastern Missouri a couple of weeks, and if it does or doesn't work I'll add a post.
Thanks.
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 10-26-2007, 12:45 PM   #7
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Hey Jim; Aerowood is giving you the best advise. The only thing I want to add is use of a Stainless Steel roll pin. Reason is that you cannot keep water out of the hinge, the steel will rust being high in carbon. If it ever rusts out you will have hard time drilling it out in order to replace it. SS will not bleed rust marks on your hinge. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 10-26-2007, 12:53 PM   #8
1967 22' Safari
AMARILLO , Texas
Hinge pin
Since you can't keeps yours in, can anyone tell me a good method of getting mine OUT of a '67 Safari. Won't budge and I would like to replace it.
10brink is offline   Reply With Quote
Old 10-26-2007, 01:03 PM   #9
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
I drilled a 1/16" hole and inserted stainless steel cotter pin from outside in (inaccessible with door closed).
Hinge pin hasn’t moved since and you can no longer simply knock out hinge pin and lift door out (antitheft device)
Safari64 is offline   Reply With Quote
Old 10-26-2007, 01:18 PM   #10
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Let us know how it turns out. I know of three other 2006/2007/2008 Airstream owners besides myself and you, that this is happening to. Two have had dealers' fix without success. In fact that constitutes everyone that I personally know who have gotten a new Airstream.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 11-11-2007, 05:18 PM   #11
2006 28' Safari
Rockport , Texas
Thanks, folks. I'm going to try Aerowood's suggestion about the roll pin. Incidentally, for 10Brink, how about drilling a hole in the top of the hinge pin, threading it, screwing in an appropriate machine screw, and using that machine screw to pry out the hinge?
Old 11-11-2007, 06:00 PM   #12
2004 30' Classic
Lillian , Alabama
Had this happen to my 99 Safari and also to my 2004 Classic so I assume it is a common complaint. Got to carrying a hammer in the truck to tap it down at every stop. At one point it came out so far that it cleared the bottom hole and dirt got into the hole preventing the pin from seating all the way down (those dirt roads in Alaska are murder). Stopped by Jackson Center on my way home from Alaska this summer to have some service work taken care of and they drilled a hole and inserted a pin. They sealed the hole with the silver seam sealer (can't remember what it's called). Seems like a simple and effective remedy.
brijbldr is offline   Reply With Quote
Old 11-12-2007, 08:25 AM   #13
Auretrvr's Avatar
Iowa City , Iowa
Loctite (with surface prep) has worked for me...
I used the Permatex surface prep and red loctite products to secure the pin in our '83 310 motorhome and it has stayed put through a 500 mile vacation trip. I think for this to be effective you must clean and prep the pin first.
AIR 15765
Hinge pin Goin camping Doors & Locks 24 04-25-2012 06:14 AM
Door Hinge Pin Comes out 64Vette Doors & Locks 26 09-27-2007 04:34 PM
Door hinge pin? 65 overlander Doors & Locks 3 09-10-2005 01:04 AM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 10:26 AM
