Old 06-27-2005, 07:02 AM   #1
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Rivet Suicide door rebuild options?
i have a '59 Traveler that i've just started the shell-off restoration on. actually, the shell's coming off this weekend. anyway, i'm trying to get my plan together for the body work needed. the unit has a suicide door, that like many others, flew open during transit.
the door needs a total rebuild, so it got me thinking. the doors are admitedly flimsy, and the skin on mine has seen better days, so my plan is to add additional bracing inside, install a port hole window in the smaller door, and possibly re-hang the door so it opens to the right.
i like the look of the suicide door, but it really catches the wind while towing. if i keep it like it is, i feel the need to add a latch at the top and botttom, to keep it snug with the body.
does anyone have any experience with rebuilding and stiffening these doors? i want to weigh all my options before i get started. thanks!
A-Merry-Can is offline   Reply With Quote
Old 06-27-2005, 07:09 AM   #2
greg176's Avatar
Gabriola Island , British Columbia
The door may be flimsy because of cracked frames inside. I think you will find it quite solid if you reskin it with .040" 2024-t3 aluminum and repair any cracked frames.I think it is best to keep the door opening as it is so it would not interfere with an awning installation.Maybe add a better latch.
greg176 is offline   Reply With Quote
Old 06-27-2005, 09:29 AM   #3
I have a '59 Traveler too. I have also built a new door for our other trailer (with port hole type window in center door). From the outside the construction of the Traveler door looks like it has a Z shaped member (with 90 deg angles) running along the perimeter - similar to our other trailer. Check for cracks in this section. A replacement can be fabricated buy bending the Z shaped member and then using both a shrinker (inner curve) and a stretcher (outer curve) to finish the shaping. Google up "Lancaster shrinker". The door hinges look like they might work if you reverse the opening of the door. The remaining issues would be locating a lock that would work the other direction (if the current is not reversable) and having a bunch of rivets pluging the old door hinge location.
Here is a pic of the El Rey door if I managed to add the attachment correctly. If not, email me for detail pics and more information.
Hope this helps,
Craig
Craig T is offline   Reply With Quote
Old 06-27-2005, 04:29 PM   #4
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
nice door!
wow! that door looks really nice! i'm definitely going to add a window once i get to that stage. hopefully, the shell's coming off this weekend, and the frame work done the following. with any luck, i'll have the body back on within a month, and i can start focussing on the body, and the door.
thanks again for the pic. if you have additional ones, i'd love to see them.
jp
Old 06-27-2005, 05:53 PM   #5
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I'm going to add a deadbolt lock to mine to keep the door in place while traveling. This also has other obvious advantages. Do a search on the forum for deadbolt installation. There's a couple of guys here who did it and documented their results. Looks great and doesn't seem too hard to do.
www.nesa.org
Air No. 6427
Old 07-04-2005, 02:07 PM   #6
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
rehanging door
well, after looking at it, i think when i get the shell back on, i'm going to rehang the door from the right side. as it turns out, the panel behind my door has significant damage, and i'll end up replacing it anyway (which would cover the holes for the original hinges), and more importantly, if i hang the door to open to the right, i can attach it directly to 2 of the internal ribs. the ribs to the front of the door opening are only a couple inches apart, since the nose cone part starte tapering about there.
i think it will be a safer option (even though i know it's a problem with the awning later, if i get one that stays attached to the body). i'll still go the deadbolt route, though, for safety.
my door panels are so beaten up, that i'm planning on replacing most, if not all of them anyway, so redrilling the hinges on the right won't be a problem at all. i still want to do the port hole window, though! that is TOO cool to miss on! plus, with all the fabrication i'm planning, it can't be all THAT much additional work.
that project is a ways off, though. first things first. i have a shell to pop off!
jordan
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
AirstreamForums.com Member Sticker? Andy R Our Community 171 06-08-2007 10:12 AM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
Mister Heater/cheap heating options? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-14-2002 02:03 PM
Questions about the 2003 International. Would you buy again/fair price. Debbie 2002 - 2005 International 29 11-07-2002 04:11 PM
