Old 03-06-2007, 09:34 AM   #43
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Okay folks - Suicide doors are to the hotrodder the epitomy of style in a 30's steetrod, or a later custom. The way I look at it I've acquired a factory built hotrod attachment. Many people who have looked at the trailer have commented on how welcoming an entrance it makes for the trailer when the door is open. It just says "come on in, the door is truly open". When you walk up to it there's not a door to have to walk around, and even with the awning leg there it still leaves a nice open feeling to guests.
Or that's my story and I'm sticking to it.
Barry
safari57 is offline   Reply With Quote
Old 03-06-2007, 12:29 PM   #44
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
i've got sui-s on 2 outta 3 of my babies! i'm with ya!
jp
8576 • • • • • • • •
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 10-13-2014, 09:47 PM   #45
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
This is a very old thread but thought I would ask here anyway.
I'm particularly interested in responses from anyone who has repaired a suicidal suicide door.
Our suicide door flew off on the freeway today. The door came off of the trailer with the hinges attached. The door failed at the rivets that attach the hinges to the trailer.
Have any of you reinforced the aluminum on the trailer after having lost a door on the highway? The holes were the rivets were are large, no longer flush (they stick up kind of like little volcanoes now) and a few of them have small tears.
We may add a hasp like Brad's and we're trying to decide about reinforcing the aluminum on the side of the trailer. (http://www.airforums.com/forums/f453...ari-25182.html post #10)
Our deadbolt wasn't enough to keep the door closed. It was still dead bolted when we picked it up by the side of the road. The handy dandy wooden doohickeys are nice but our '59 doesn't have an outside grab handle.
What to do? Limp 500 miles home with a plastic over the door or fix it on the road?
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 10-13-2014, 10:05 PM   #46
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Fix it on the road like I did. I added a bunch more rivets to the door hinge to side of trailer and used the next size larger than what was on there so I could use the same holes after flattening down the 'volcanos' as you call them.
My road trip repair has held up for 12 years. Don't forget the vulkem once you get home.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is online now   Reply With Quote
Old 12-28-2014, 06:50 AM   #47
"Sassyfras"
oledawg's Avatar
1994 30' Excella
Winston-Salem , North Carolina
Hmmm, "wooden dohicky" would have been nice when my suicide door came open while traveling yesterday...is there a source?Click image for larger version
Name:	ImageUploadedByAirstream Forums1419774618.030934.jpg
Raconteur, Bon Vivant, Curmudgeon, and other depending on Susan's mood at the time...Retired, so don't ask me to do a damn thing
oledawg is offline   Reply With Quote
Old 12-28-2014, 07:09 AM   #48
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
No source for a 'doohickey' since every trailer is different. Should be fairly easy to make your own if you have a band saw.
FF
Old 12-28-2014, 08:32 AM   #49
Wayward's Avatar
Cary , North Carolina
If the hinges fail like that, certainly the deadbolt is of no use.
If hinge failure is a problem on certain models I am surprised no one uses the pin modification. This is something we do on outward opening exterior doors so that they cannot be broken into by removing the hinge pins and pulling the door deadbolt and all.
The pin must penetrate the door and the jamb enough that it could hold in place without a hinge.
They can be placed anywhere on the door jamb - they do not have to be placed at the hinge.
On an Airstream hollow door it might require a through bolt or some reinforcement around the pin.
You can also buy a similar product which replaces a hinge screw, from security stores.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 12-28-2014, 08:38 AM   #50
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Although really cool, these won't work because the hinges are external and not concealed like in the illustration above.
FF
Old 12-28-2014, 08:41 AM   #51
Wayward's Avatar
They can/should be placed in the door jamb - they need not be on the hinge.
http://www.peerlessdoorlocks.com/jambpins.html
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 12-28-2014, 08:45 AM   #52
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Easier than a wooden doohickey is a rubber doorstop inserted under the grab handle through to block the door from opening. Put a little bungee on it and loop it through grab handle to keep it handy when traveling, hang it on the key hooks when in camp.
Doug and Cheryl
Old 01-22-2015, 08:16 AM   #53
Someday'59's Avatar
Images: 18
finally ready to talk about it
We did limp home, then fixed the door. Three months later, I am finally read to "talk about it."
Here's the story about the door falling off: 1959 Airstream Overlander, "Someday": That Time the Door Blew Off
Here's how we fixed it: 1959 Airstream Overlander, "Someday": Assessing the Damage
~Lynnetta
Old 01-22-2015, 08:36 AM   #54
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Airstream Article
Back when this thread started I posted an article under the menu drop downs at the top of this page. Click 'More' and you will find a number of interesting articles about Airstreams. Mine on this subject is the second one listed.......oh alright here it is ; Make Your Own Suicide Door Security Latch
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
re-plumbed '67 Safari tod47d Plumbing - Systems & Fixtures 4 01-30-2006 11:04 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 02:04 PM
Safari Availability JLD 1974 - 1979 Safari 4 09-12-2002 08:32 AM
Towing my 1964 Safari - what tow vehicle do I use Neenm Tow Vehicles 6 06-28-2002 04:26 PM
