Old 03-20-2015, 10:13 PM   #15
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by TG Twinkie View Post
I don't think welding the cast steel handle will work. Sent from my iPod touch using Airstream Forums
I've had good luck with an L77 and L66.extra material was added to the back of the handle to beef it up. Not as strong as yours but still original looking.
desertair27 is offline   Reply With Quote
Old 03-20-2015, 10:42 PM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Cast steel welds pretty good, cast iron is a big challenge.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 03-25-2015, 09:47 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I don't have any more handles for the L-77 lock assembly.
Thanks to all who purchased.
Old 04-05-2015, 03:15 PM   #18
1973 31' Sovereign
FLORIDA , Florida
Hello im new to the airstream. I need door lock complete dont know the number it is .as someone lost the key and remove the lock complete and no part can be found its a 1973. Sovereng 31ft.i cant seam to find aftermarket. Any information is appreciated. Also could one of the newer smaller outside handles be fitted until I find the correct one. thank you. D. Workman.
Davidlee is offline   Reply With Quote
Old 04-05-2015, 10:04 PM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I believe your coach has a KT handle assembly. Some parts are available from Vintage Trailer Supply. Or Out of Doors Mart. There are also replacements for that unit. But require some significant modifications to install.
Old 04-06-2015, 08:39 AM   #20
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Can you post a picture of what you have if you have any door lock at all?
Mike
Old 04-07-2015, 02:48 PM   #21
1973 31' Sovereign
FLORIDA , Florida
Hey. Mike thanks for helping. I have no parts of door handle or lock I just have a rectangle opening. About 3in x7in aprox I need to remesure it. Someone put a hasp and. padlock on it. Thanks for any advise. David.
Bargman L-77 Door Handle Lock Assembly G R Parker Doors & Locks 7 05-06-2010 04:41 PM
Found....new Bargman door handle/lock for many '50s to '60s Rog0525 Doors & Locks 45 10-31-2009 12:05 AM
'60s Bargman L-77 door handle!!! airhead Doors & Locks 5 07-01-2005 07:32 AM
plasticcoate substitute Bradjun1 Clearcoat, Exterior Paint & Trim 2 05-05-2005 09:02 AM
Substitute for a House? Jimbo7508 Full-Timing 19 01-03-2005 10:00 PM
