Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 11-08-2010, 03:04 PM   #41
dznf0g's Avatar
Oswego , Illinois
Originally Posted by dznf0g View Post
The newer trailers with a keyed deadbolt still have an issue.....although I don't think it is a lack of "detent" or slamming issue. It is REALLY easy to hit the deadbolt lever from the inside when pulling the door latch handle. If you move the deadbolt lever just past the detent, it will lock when slammed. But, several keys, in several locations takes care of any mishap.
Excuse me, my previous comment pertains to the regular doo handle lock mechanism...not the deadbolt!
My unit has:
1)the door handle latch/lock mechanism. locks with key from outside and a sliding lever on inside
2) a deadbolt. locks with key from outside and a twist knob (like your house) on the inside.
From what I am reading...there are several different styles in the past few years???????
Old 11-08-2010, 03:39 PM   #42
SteveH's Avatar
Common Sense , Texas
My unit has:
Yes, you have the newer type....don't know the year, but at least AFTER '01, because our '01 had the slide pin type of deadbolt that would lock itself from slamming the door, or sometimes it would do it on a rough road.
The newer type that you have, and is on my '04, has a keyed deadbolt lock, but the problem that this door lock develops is not with the deadbolt, but rather the regular door lock. It locks itself, and sometimes won't even unlock with the key.
The one that Andy has the repair kit for is the "not so new" one that uses a slide pin.
Regards,
Steve
Old 11-08-2010, 04:01 PM   #43
HCR
HCR's Avatar
Livingston , Full time traveler
Happened to me just a few days ago and of course I had not seen this thread until today. Cost me $150 for a locksmith to pick the lock --he needed less than two minutes to do so.
Yes, it locked because I slammed the door in the wind. How could this design flaw not have been corrected long ago?
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 11-08-2010, 04:09 PM   #44
Steve.
Please stop quoting what we have and what we don't have and what it may fit.
You are dead wrong in your statement.
We appreciate trying to help, but in this case, your wrong.
Thank you.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-08-2010, 04:20 PM   #45
dznf0g's Avatar
Oswego , Illinois
Because their list of things needing correction is so long and overwhelming that they are frozen due to anxiety?
Old 11-09-2010, 01:02 PM   #46
2007 25' International CCD FB
benicia , California
I'm in !!!!! Thanks to Andy / inland rv for the info.no locksmith no broken windows
Off to make more keys!!!!!
wjpjump is offline   Reply With Quote
Old 11-22-2010, 04:43 PM   #47
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
More confused than when I started
From what I've read in this and some parallel threads on the subject, Andy has a fix for a deadbolt that can lock itself if the door slams and that this problem appears to be pervasive on later model trailers. It appears that there may be different types of lock hardware and the problem locks are those that have a deadbolt separate from the main lock and this deadbolt may have a pin or lever that slides in a slot to activate it.
I've attached a photo, remember the adage that a picture is worth 1,000 words. My deadbolt has a rotating knob that feels like there is a cam inside to act as a detent. This deadbolt can be operated from the outside using a key that is different from the one on the main lock. It is possible trip the lever on the main lock as you're going out and when the door closes, it is locked, but not by the deadbolt.
Is this design different from the one Andy's kit fixes?
Name:	2008 Classic 27FB Door Locks.jpg
Silver Goose is offline   Reply With Quote
Old 11-22-2010, 04:59 PM   #48
SteveH's Avatar
Originally Posted by Inland RV Center, In View Post
Steve.
Thank you.
The one that I got the repair kit from Andy for was the "not so new" one that uses a slide pin.
Do you like this statement better, Andy?
Regards,
Steve
Old 11-22-2010, 07:51 PM   #49
No!!!
Nothing, I could ever do, I don't think would ever please your desires.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-22-2010, 09:05 PM   #50
SteveH's Avatar
No!!!
But Andy, I was trying to please YOUR desires.
Regards,
Steve
Old 01-04-2011, 03:29 PM   #51
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
How does the lockout kit work/ install??
Originally Posted by YankeeDoodle View Post
... Andy has a fix for a deadbolt that can lock itself if the door slams and that this problem appears to be pervasive on later model trailers. It appears that there may be different types of lock hardware and the problem locks are those that have a deadbolt separate from the main lock and this deadbolt may have a pin or lever that slides in a slot to activate it.
....a picture is worth 1,000 words. My deadbolt has a rotating knob that feels like there is a cam inside to act as a detent. This deadbolt can be operated from the outside using a key that is different from the one on the main lock. It is possible trip the lever on the main lock as you're going out and when the door closes, it is locked, but not by the deadbolt.
I just rec'd the kit from Andy- THANKS!. I have a '04 Safari with a door exactly like in post #47 above.
How do I install this kit??
Don
DJW is offline   Reply With Quote
Old 01-04-2011, 04:35 PM   #52
Don
Instructions should have been with the kit.
PM us your e-mail, and we will forward the intructions to you.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-04-2011, 04:45 PM   #53
moparjohn's Avatar
1973 25' Tradewind
Bloomsbury , New Jersey
OK, gonna ask, does this lockout and fix pertain to certian years of trailers? Or all of them? I have a 1973 Tradewind, and will def. send my SASE if it is possible for mine to lock. MPJ
moparjohn is offline   Reply With Quote
Old 01-04-2011, 05:42 PM   #54
Nope, it's not for the 70's trailers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-04-2011, 05:51 PM   #55
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Andy,
I have a 1997 Excella 1000 30'. Do I need the afore mentioned kit?
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 01-04-2011, 06:00 PM   #56
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I used to lock myself out on my 73 all the time with my after market deadbolt. I solved the problem in 2 ways: 1. a tiny bungee I hooked on the deadbolt when not in the trailer and in case I forgot to do #1 a length of coat hanger with right angle bends on each end.
Old 01-04-2011, 08:13 PM   #57
Originally Posted by bwoodtx View Post
Andy,
Yes.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-18-2011, 06:56 PM   #58
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Lockout Kit Needed?
Is the Lockout Kit needed/recommended for a 2006 25' International Ocean Breeze? If I understand the discussion so far on this thread then I am thinking the answer to my question is "yes" ... but if someone can confirm my understanding it would be most appreciated.
Frank&Mike is offline   Reply With Quote
Old 01-18-2011, 06:59 PM   #59
Your question can be answered in 2 words.
Yes sir.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-22-2011, 05:04 PM   #60
1998 25' Excella
Fredericksburg , Texas
Images: 11
Here is my fix
This is what I did.
A rubber band and a 3M stick on hook. Total work time: 10 seconds.
dacantu is offline   Reply With Quote
Dead Bolt Dbraw Doors & Locks 17 06-23-2014 10:34 PM
'93 Legacy, dead bolt geodrake Land Yacht/Legacy Motorhomes 2 08-22-2007 10:56 AM
Dead Bolt Installation balrgn Doors & Locks 28 11-05-2006 09:26 PM
Dead bolt Scaler113 Doors & Locks 0 11-08-2004 08:20 PM
dead bolt joel Doors & Locks 1 08-25-2002 08:35 PM
