1989 29' Excella
1999 25' Safari
Youngsville
, North Carolina
Standard size door?
I have a 89 29' excella. Main entry door came loose while towing, ouch ! Now door is bent. I plan on trying to straighten it out, but if not successful, are all the doors a standard size? or do they vary by size and or year? Any feed back would be appreciated.
Although I can not answer your question specifically, I am amazed Airstream mounts doors hinged on the left side. Guaranteed to be a problem eventually. We have decided to double lock the door each and every time while on the road and hopefully avert an unplanned opening.
1989 29' Excella
1999 25' Safari
Youngsville
, North Carolina
KOSM1O,
Thought I had latched and set deadbolt. Much to my surprise, looked back and saw door swinging open. Had not gone 3 mi. Hope I don't have to replace it.
Door straightening blocking instructions were posted on a thread yesterday. Has the photos and instructions in case you didn't see it. I believe I saved it to a file if you can't find it and need the information.
