Old 08-07-2004, 04:45 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Sprung door... one man's solution
Although it has never happened to me, I am somewhat worried about my door popping open and forever being sprung.
Also with a slightly polished exterior I did not want to do anything external that would take away from the look.
I decided to put an eye bolt through the floor plywood under the sink. From there I put a bungie cord that attaches to the screen door handle, which is quite sturdy.
The idea is this. You close the door most of the way and connect the bungie on your weigh out. The bungie holds the door pretty much closed without too much pressure, but enough so that if the latch works itself open the door won't be flapping in the wind.
Seems like it should work to me. If it won't don't tell me cause I want to feel like it will
ID:	8195   Click image for larger version
ID:	8197   Click image for larger version
-Tim
theVAP - Airstream Podcast
Old 08-07-2004, 06:41 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Should work
I did the same on my old Scamp. It didn't have the suicide door, but the door kept coming open because of the lousy lock that Scamp put on. I would go around a corner or over a spped bump and the door would fly open. With the bungee, there was never a problem.
Of course, the best solution is to install a dead bolt like on the newer trailers.
John W. Irwin
WBCCI #9632
Sewer Solution frozen chosen Waste Systems, Tanks & Totes 20 07-26-2004 07:05 PM
Single sheet vinyl solution? TomW Floor Finishes 19 03-26-2004 07:53 PM
Ground bracket solution for awning yukionna Awnings 3 10-05-2003 09:09 AM
Lazy man's shining methods VegasJoe Cleaning, Stripping & Polishing 4 03-28-2003 04:36 PM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
