Old 02-02-2011, 06:21 PM   #15
LisaP's Avatar
2008 25' Safari SS SE
Colleyville , Texas
Sorry to hear that. Maybe someone will chime in with more advice.
In a perfect world, every home would have a dog and every dog would have a home.
LisaP is offline   Reply With Quote
Old 02-02-2011, 07:47 PM   #16
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I cannot figure out how the door opened if you had the magic wood bar in place.
Old 02-02-2011, 07:56 PM   #17
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
It wasnt the wood bar, it was a door wedge (like the one that there are pictures of floating around somewhere on the forum) but I can't figure out how it came out either, since we hadn't had any problems with it coming loose (and have been on the road for about two weeks)
MonaxLisa is offline   Reply With Quote
Old 06-17-2011, 06:09 PM   #18
1986 31' Sovereign
Bend , Oregon
TG,
What is the name and where do I find this Door Latch Hardware??? I have a 86 Sovereign with a slight sprung door in the same area as your Argosy.
Thanx,
Geno Dusan- Bend,Oregon
geno.dusan@gmail.com
t
Geno Dusan is offline   Reply With Quote
Old 06-17-2011, 07:31 PM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Geno; If you are refering to the devices with the red handles. They are commonly used in wood working to hold the work down. Called "Quick Release Toggle Clamps".
Go to www.EagleAmerica.com The part # is 449-2029
Hope this answers your question.
TG Twinkie is online now   Reply With Quote
Old 06-18-2011, 05:37 PM   #20
Check the striker bolt and striker pocket for excessive wear.
Also check the striker pocket to make sure the brass shim is still in place.
The door usually flies open, because the lock is not engaging properly.
Sprung doors, usually tear the door frame in half, on the inside part of the frame, where the striket bolt protrudes.
You should have it welded, or add a very stiff stiffener plate to correct the problem.
Warped doors that use an extrusion, can usually be easily fixed.
Warped doors that used the cast frame, is another story, as it cannot easily be bent back in place, without the risk of breaking the casting in another area.
Mystery Door Leak - Help Needed MDSilverado Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 02-14-2011 01:11 PM
Argosy Door TG Twinkie Doors & Locks 7 01-29-2011 06:11 PM
interior trim around door removal? Bill M. General Interior Topics 2 01-24-2011 08:25 AM
Can't get door to latch closed drew05 Doors & Locks 10 01-12-2011 08:33 PM
RM 2410 and 2510 Freezer Door Widths pbearsailor Refrigerators 4 01-07-2011 07:16 PM
