Old 05-14-2010, 11:02 AM   #1
1973 23' Safari
Portland , Oregon
Spring broken in outside main door hold back latch catch
The spring is broken inside of the outside main door hold back latch catch and I am wondering how to replace it?
I'm not sure if I am calling the latch catch the proper term, so I've attached a photo.
Pre-thanks for any suggestions or tips on how I can go about putting a new spring in there.
Biggysmalls is offline   Reply With Quote
Old 05-14-2010, 11:16 AM   #2
Kevin245's Avatar
Hey Biggysmalls,
I sent you a PM with some information.
Kevin
Eleanor Roosevelt
Old 05-14-2010, 11:30 AM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Vintage Trailer Supply,you just as well buy the plastic parts,they are next to go. Dave
easyride is offline   Reply With Quote
Old 05-14-2010, 11:34 AM   #4
1973 23' Safari
Portland , Oregon
I think the parts are in working order, although I appreciate that they may break in the future. My main goal is to learn how to take off the existing part, remove and replace the broken spring and re-attach properly.
Thanks!
Old 05-14-2010, 11:54 AM   #5
easyride's Avatar
1977 27' Overlander
Naples , Florida
Drill out the old rivets,you can probably get a new spring at any hardware store,put a little sealer on the new rivets,I would use Olympic rivets,they just look better than pop rivets. Dave
Old 05-14-2010, 11:56 AM   #6
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
I used the spring off of a screen door roller from Lowe's. The spring was perfect.just remove the rivets replace the spring and re rivet the assembly
arodriguez60 is offline   Reply With Quote
Old 05-14-2010, 11:56 AM   #7
Thanks!
Remove the 4 pop rivets with a # 30 drill bit.
Fix or replace the holdback as you wish.
Reinstall the bracket using four 1/8" pop rivets with a little sealer around the base of them.
Replacing everything except the metal bracket, is the way to go, as it's pretty cheap.
It's an Airstream dealer part.
Reattaching screen-to-main door latch funkill Doors & Locks 11 06-05-2016 12:01 PM
Latch/Catch for compartment door slk Exterior Storage Compartments & Access Doors 1 05-02-2010 08:09 AM
Sliding Latch Door catch broken '72 Tradewind RichHog Doors & Locks 8 09-25-2009 04:04 AM
Main door latch needed '69/'70 tradewind Eliminator46 1970-79 Tradewind 6 10-11-2008 05:19 AM
How does the main-door hold-back work? monocoque Exterior Storage Compartments & Access Doors 3 03-20-2008 03:55 PM
