Old 08-13-2006, 05:55 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
sourcing entry door seals for a '64 Globetrotter
I need to replace the door seal on my Globetrotter, and have tried a couple of things already with limited success. It looks like a 9/16" L shaped gasket, 3x8" on each leg of the el, and that would compress from 3/8 to 3/16, would work the best. I bought two products from two different vendors, and neither product fit, or rather, allowed the door to shut with the seals in place.
I think my door is little sprung, out at the top and the bottom, so I'm thinking that if the gasket was thick but compressible, it might fill the wider gaps?
Any thoughts would be great
thanks
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 08-14-2013, 04:45 PM   #2
jessejane's Avatar
little river , California
Hi. I'm having the same problem and was wondering if you found a solution? I've been looking at parts on VTS and other sites, and all the door seals seem to work for trailers up to 1963 and others work for trailers from the 70s on, but I can't find any that say they work for a 1964 globetrotter. If anyone can point me in the right direction, I'd greatly appreciate it. I need a seal for the door as well as for the door within the door. Thanks!
jessejane is offline   Reply With Quote
Old 08-14-2013, 06:03 PM   #3
Central , Mississippi
Is a '64 the same as a '62? I know the 63 inner door hinge is an oddity and they went back to the old style in '64. You may have luck with a '62 gasket.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-15-2013, 09:15 PM   #4
jessejane's Avatar
It's worth a try! I haven't been able to find any other information, and I'm going to try that out. I'll let y'all know if it works out. Thank you!
1964 GlobeTrotter InsideOut 1960 - 1964 Globetrotter 3 09-29-2005 11:56 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 09:41 PM
