Old 11-28-2010, 01:20 PM   #1
1974 25' Tradewind
roseville , Michigan
Someone tried to break in/Lock busted!
Hi, we have a 1974 Airstream. We keep it up north for hunting. We just found out that someone tried breaking into it, and has busted the lock. The key hole is broken, where a chunk of metal is missing, and when you do put the key, it just spins and spins. Along with that, the outside handle is useless. We had to climb in through a window & open it from the inside. Right now, if we lock the door, there's no way to get in... unless we use the window again. Anyone have any ideas???
chelliepport is offline   Reply With Quote
Old 11-28-2010, 01:31 PM   #2
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
See if vintage trailer supply has what you need,they just may have a new handle that works .
Rollerboy is offline   Reply With Quote
Old 11-28-2010, 01:36 PM   #3
x
XXXX , XXXX
It sounds like so much damage has been done that you have no choice but to replace the entire door lock. Inland RV and Out of Doors Mart sell them. They are not cheap, but if the lock casing is damaged then new parts won`t help you.
wasagachris is offline   Reply With Quote
Old 11-28-2010, 03:07 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Sorry to hear about the damage. I know Inland RV sells that door lock, you have the same setup as my '72. I believe the lock costs around $400-500.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 11-28-2010, 03:20 PM   #5
You have a KT lock.
The complete replacement is very expensive, as it is only available from Airstream or an Airstream dealer.
Or, you can upgrade to a different lock kit, at about 1/3 the cost.
Old 12-08-2010, 11:21 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Fix it
I would take the lock out of the door and examine it for damage. Chances are it can be repaired. If it is the same lock I have on my '74 Argosy it is a very simple mechanism. In one of my previous posts there is an exploded view of the lock. A lot of the parts are available thru Out of doors Mart. Look for a thread titled. " '73 door handle when to crap" on 11/23/10
Old 12-17-2010, 07:27 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Lock
Did you get your lock to work?
1974, broken, lock, main door
Busted sink berickn 1970-79 Tradewind 5 12-08-2009 07:24 AM
Search Function Busted 66Overlander Forum Admin, News and Member Account Info 6 11-27-2007 09:09 PM
busted pipes sfixx Fresh Water Systems 36 04-07-2005 08:51 PM
Busted Vista View Holzarbeiter Windows & Screens 11 03-28-2004 02:33 PM
Converter busted? Navigator Electrical - Systems, Generators, Batteries & Solar 4 01-06-2004 10:22 AM
