Old 05-31-2009, 08:40 AM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Sliding Latch Door catch broken '72 Tradewind
The Latch is broken that holds the door open on my 72 Tradewind. It is a sliding black latch riveted to the skin. That part looks good but the other half on the door appears to be broken where the latch connects to hold the door open. Been using a bungie cord to strap it back so door doesn't flap in the wind but would love to fix latch the way it was designed. Any parts or work arounds?
Richard
RichHog is offline   Reply With Quote
Old 05-31-2009, 09:49 AM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Richard
Hi, Rich. Can you take a pic. It sounds like the base piece is intact but you're missing the top piece and spring. Is that correct? I just repaired all of my latches so I know what you're going through.
I bought my latch replacement parts from Oasis RV in Tucson. I also salvaged two complete latches that were part of a overhead storage tub. These parts are no longer made but you can still find them if you look hard enough.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-31-2009, 10:23 AM   #3
Kevin245's Avatar
Hey Richard,
I think it's the same part on our 76. I bought one and a couple of extras from Inland last year. The tip that catches under the body mounted slide bar broke on mine too. I keep the extras in a tool drawer along with my trusty pop-rivet tool.
Eleanor Roosevelt
Old 05-31-2009, 11:40 AM   #4
Richard
The new style "entrance door holdaback" consiste of a metal housing and a better black plastic latch.
Airstream has used that latch for about 35 years.
Old 05-31-2009, 04:04 PM   #5
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Door Latch
Here are two pics, one of the latch one of the catch. How to repair or replace?
ID:	81232   Click image for larger version
Old 09-24-2009, 06:11 PM   #6
1973 31' Excella 500
Flagstaff , Arizona
Richard, can't access your thumbnails. You have what sounds like a similar problem I'm having and I wanted a look at that latch. Any live link to the attached thumbnails? The one on the post above do not work.
JO in N Arizona
Jo Baldo is offline   Reply With Quote
Old 09-24-2009, 10:30 PM   #7
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Latch
Will look for the pic and upload, I got a local RV repair shop to replace it.
It is the same latch that is used inside the closets and pantry in my Tradewind if that helps you.
Old 09-25-2009, 02:06 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Your OEM latch is unavailable as new. The best replacement is the latch Andy speaks of above.
Old 09-25-2009, 04:04 AM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you really want the original - you could part it out from the available cabinet latch kit.
Cabinet Catch Assy 1971-74 Brown 201148-01 [201148-01] - $14.95 : ODMRV , Out-of-Doors Mart
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
Basement latch broken jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 06-26-2011 03:49 PM
Can't get door to latch closed drew05 Doors & Locks 10 01-12-2011 08:33 PM
