Old 11-07-2011, 06:42 AM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
I am reskinning my door and rethinking the lock options. I know the cast oem locks are weak and priced like they are cast from gold, so I'm thinking of having just a pull on the door and moving the lock / deadbolt to the right of the door on the shell. Maybe use a commercial door lockset. Anyone do this??
Thanks..
Darkspeed is offline   Reply With Quote
Old 11-07-2011, 07:25 AM   #2
Thanks..
Whatever you do, keep in mind that thinning the cast entrance door frame, will weaken it, which usually results in the frame cracking.
I would suggest, staying with the original, in spite of it's cost, since that's much cheaper than repairing the cast door frame.
Old 11-07-2011, 08:11 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I have essentially the same deadbolt retrofit as TG Twinkie, shown here.
Mine was installed by the PO and works well.
— David
Old 11-07-2011, 08:23 AM   #4
Darkspeed's Avatar
1972 31' Sovereign
This is the door that i am rebuilding as a longer door and i was planning on tig'ing in some reinforcement anyway.
Old 11-07-2011, 08:26 AM   #5
Darkspeed's Avatar
1972 31' Sovereign
Ah! cool! That was what I was thinking with the addition of a lock / knob
Old 11-07-2011, 08:28 AM   #6
Darkspeed's Avatar
1972 31' Sovereign
I was thinking something like this..
Old 11-07-2011, 09:24 AM   #7
That will work.
Keep the hole as small as you can for a dead bolt.
The dead bolt can be cut down to a fraction of it's original size.
Old 11-07-2011, 11:44 AM   #8
Darkspeed's Avatar
1972 31' Sovereign
That will work.
Thanks Andy thats a good point...
Old 11-07-2011, 11:58 AM   #9
richinny's Avatar
2011 34' Classic
if you can find something with a round deadbolt hole, would it be keep the frame stronger? i can't really tell from this pic but it does look rounder than the oval ones i usually see.
kwikset security deadbolt lock
Ricky
Old 11-11-2011, 07:08 AM   #10
Darkspeed's Avatar
1972 31' Sovereign
Well you could pull the bolt out and throw it on the lathe and turn down the diameter. I don't know what hardness those bolts are though.
Old 11-11-2011, 07:44 AM   #11
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I used stainless lock assemblies found in the marine supply area. Many styles that look great and work well on an Airstream. Check 'em out. I hate house type locks...they always LOOK like they belong on a house.
Old 11-11-2011, 09:14 AM   #12
Darkspeed's Avatar
1972 31' Sovereign
That's a good idea
Modernism Week/Vintage Trailer Show WRDinAZ Off Topic Forum 2 02-13-2011 12:43 AM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 09:44 AM
Show Me Your Wheel Well Patches skittles Wheel Wells 5 01-20-2011 06:26 PM
Chicago Boat, RV & Outdoor Show Jan. 12-16, 2011 Jezibels On The Road... 3 01-11-2011 12:22 PM
NOVA Cleveland Ohio RV show DanB WBCCI Rallies & Events 8 01-08-2011 08:18 PM
