Old 06-17-2009, 08:02 PM   #1
2009 30' Classic
Salem , Alabama
Sheared door locking mechanism upper bolt
I just discovered a sheared upper bolt(one of two) which holds the opening/closing/locking door hardware in place. The bolt head and appr 1/4" of the thread is completely sheared off. The remainder is holding. Can the damaged bolt be removed and replaced, short of drilling?(2009 Classic L 30).woppa4
woppa 4 is offline   Reply With Quote
Old 06-18-2009, 07:00 AM   #2
2009 30' Classic
Salem , Alabama
Sorry: The sheared bolt in the one;which holds the upper plastic retaining claw or (locking claw) in place.woppa4
Old 06-18-2009, 07:05 AM   #3
Your selling dealer should replace the lock in Warranty.
Old 06-18-2009, 08:39 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Sorry to hear about your issue Woppa4, and though I don't know specifically the answer, I would agree that any Airstream Service center should be able to fix it. If the bolt sheared off, I would think something larger is at hand possibly and if you mess with it, they could very easily try to walk away from it. The factory lately has been, from what I've read here on the forum, becoming somewhat selective on what they are going to cover as a warranty issue, things that they never did balk at before, they are balking now. So be careful how deeply you get into it.
Window opening/locking mechanism replacement jtsanchez Windows & Screens 5 05-14-2012 11:47 AM
Replacing locking mechanism perryg114 Refrigerators 0 11-13-2011 04:18 PM
Upper shock mount sheared off 89 Excella pjg5842 Shocks 0 06-12-2011 08:17 AM
What is the best locking mechanism for cabinets? pamelake Cabinets, Counter Tops & Furnishings 4 02-10-2007 07:14 PM
