Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 05-18-2016, 12:13 PM   #1
Oldsalt47
John Oliver's Avatar
1985 31' Sovereign
Severna Park , Maryland
Securing Entry Door while underway
Any ideas, suggestions, etc. as to how to secure entry door while traveling. My 1986 31' Soverign has rearward opening "suicide door" with nothing except main lock/latch to prevent catastrophic opening.
In ten years I have never had a problem, but always have visions of door flying open while crossing over Bear Tooth Mountains, or on I-80 outside Cheyanne Wy !!
Would like to come up with something, other than hasp type lock, that does not require punching holes in the shiny stuff !!
Thanks in advance for the tips
Oldsalt47
1986 31' Soverign
2007 6.0L GMC Yukon XL Denali
Co-pilot Remington Shur Shot 90 lb Black Lab
John Oliver is offline   Reply With Quote
Old 05-18-2016, 12:19 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We had one of the very early 2005 25FB's. These also had the rear-hinged entry door. I towed that trailer about 120,000 miles in eight years. I never had any problem with the door coming open while underway. I did always try to be careful about double locking before starting out. I thought about getting a marine stainless steel slide bolt for the outside of the door, but was concerned about someone come by and locking while I was inside. Therefore I never did anything and it all worked out.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 05-18-2016, 12:33 PM   #3
Oldsalt47
1985 31' Sovereign
Thanks I know what u mean about the getting "locked in" vs locked out. Being a sailor for 40+ years, I am familiar with all the exterior slide bolt type locks. Was thinking about some type of bolt that was quickly removable so it could be removed and put inside when not traveling ??
Old 05-18-2016, 12:39 PM   #4
Oldsalt47
1985 31' Sovereign
"Judgment comes from Experience, Experience comes from bad Judgment" ....... Simon Bolivar
Old 05-18-2016, 02:04 PM   #5
centennialman's Avatar
2016 23' International
Centennial , Colorado
Can you post a pic of your entry door in the closed position?
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 05-18-2016, 02:21 PM   #6
Sag Harbor , New York
Steve our FC20's also have the so-called suicide door, and I am trusting the lower deadbolt entirely to stay latched while underway. We avoid using the upper lock, which is part of the door's operable latch, except when we are both inside for the night. I don't think our upper lock is subject to,vibrating open in transit, like some older models seem to, but this is TBD I guess.
I believe the original poster here has an older lockset.
Peter
Old 05-18-2016, 02:40 PM   #7
Thanks Peter....I am curious to see if his trailer has a grab handle just to the side of the door or not. My 1966 Airstream had a grab handle and I fashioned a wooden piece that slid into it and across the door for extra piece of mind in regards to the door flying open.
When I bought my FC 20 this year the first thing I pondered was how I could make the door more secure from flying open. Haven't come up with any ideas yet.
Old 05-18-2016, 02:40 PM   #8
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
There is a gizmo fashioned out of wood that you can make to hold the door closed for the 60s trailers. Not sure about other years.
It fits in the vertical handle next to the door.
I tried to search our out but can not find it.
Maybe some one that has one will chime in
Dingo Girl is offline   Reply With Quote
Old 05-18-2016, 02:56 PM   #9
moosetags's Avatar
Here are a couple of shots of the door on our 2005 Safari 25FB. As you can see, there is a grab handle right next to the door open. A wedge as you describe is a good idea.
Brian
ID:	262733   Click image for larger version
Old 05-18-2016, 03:13 PM   #10
Here is the link for the wooden doohickie thingy. It worked well on my 1966 Airstream. http://www.airstreamcentral.com/arti...tch/Page1.html
I may still have the template in a file if anyone wants a copy. I spray painted mine gray.
Old 05-18-2016, 03:19 PM   #11
1973 31' Sovereign
Middletown , California
It seems to defy common sense that almost all Airstream doors are hinged suicide style. Does anybody know why they do it this way?
ijustlee is offline   Reply With Quote
Old 05-18-2016, 03:35 PM   #12
One school of thought is that the door would be in the way of the awning rail on some models or that it would cover a window if it opened to the right. There is more room in the center part of the trailer for the door to cover and secure when parked etc...
Old 05-18-2016, 03:41 PM   #13
moosetags's Avatar
We have had two 25FB's. A 2005 with the rear hinged door and a 2015 with a front hinged door. Given our druthers, we prefer the rear hinged door. It just works better on a 25FB.
Brian
Old 05-18-2016, 03:44 PM   #14
Dingo Girl's Avatar
1967 17' Caravel
Thank you!
I was hoping someone would have one!
Old 05-18-2016, 04:44 PM   #15
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I see in the photos that you have a deadbolt in addition to the regular door latch. Underway, I always use the deadbolt and have never had a problem.
2019 Ford Expedition Platinum
Old 05-18-2016, 05:43 PM   #16
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'd like a copy of the template, if you still have it!
Thanks!
Old 05-18-2016, 06:11 PM   #17
I have to give credit to Freshair for the design of the wooden door block. He sent me a template 10 years ago and I believe he is the one on the link I posted earlier. I don't believe he would mind if it's shared since he posted the dimensions etc... on the link. If anyone wants a copy of my template, please send me a private message with the address and I will get it mailed out to you right away.
Old 05-18-2016, 07:03 PM   #18
Our 2014 FC20 does have a grab handle to the right of the door FYI. Thanks for the link to the wooden door safety piece.
Old 05-18-2016, 09:26 PM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
With the dead bolt in place I seriously doubt any Airstream door would come open. Maybe something unforeseen would happen, a really big bump, someone forgets to close it tight.
So we went to the hardware store and bought a small rubber door stop, and a little loop bungee. Drilled a hole in the tall end of the door stop and put the bungee through it. Then when traveling we loop the bungee to the grab handle and push it under the grab handle towards the door so it blocks the door from coming open. When we go inside we pull out the stop and let it dangle from the grab handle as a reminder to put it back in place when hitting the road again.
Doug and Cheryl
Old 05-19-2016, 07:54 AM   #20
Oldsalt47
1985 31' Sovereign
Door latch
Thanks for all the input! Yes, my Soverign does have the grab handle and like others, I have used a series of different "wooden wedges" thru grab handle to keep door shut. I was hoping to find something a bit more craftsman like than a cedar wedge - although the wedge performs flawlessly !!! ( KISS ). Maybe I should leave well enough alone ...As yet. I have been unable to open files which have the prototype wooden latch. Will keep trying
Securing Door While Traveling bimpy Doors & Locks 25 03-17-2015 03:54 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Entry door flew open while going down highway Boondocker Doors & Locks 27 10-01-2011 09:12 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
Lunar Eclipse underway Boondocker Off Topic Forum 4 03-05-2007 11:26 AM
