Old 05-19-2016, 11:29 PM   #29
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Our 2006 Bambi has a "suicide door" as well ... The top lock sometimes unlocked in transit but the deadbolt stays locked so far ... but just in case, we use a rubber doorstop with a hole drilled the fat end and a bungee-ball attached to loop onto the grab handle...works great and and does not mar the finish...
Name:	Door Stop_1_Sm.jpg
ID:	262810   Click image for larger version
Name:	Door Stop_3_Sm.jpg
TB & Greg and Abbey Schnauzer
#3954
Old 05-20-2016, 08:01 AM   #30
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Article
I posted this article back in '06. Your '85 may need some modifications to this 'safety latch' to work for you. http://www.airstreamcentral.com/
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-20-2016, 08:27 AM   #31
Long Island , New York
Thanks Neil -- FYI centennialman was good enough to post your design also and credit you. Very handy, thanks for the simple solution.
Peter
OTRA15 is online now   Reply With Quote
Old 05-20-2016, 08:40 AM   #32
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use the same as TBRich, no problems. I really like the simplicity of the spring clip through a hole in the rain eyebrow mentioned earlier.
I would just mention the doorstop wedge rubs the very leading edge of the door when it contacts, there's some flex in these trailers going down the road. Hardly noticeable but I maintain it with a touch up of acrylic clear coat pen now and then to keep filiform from setting in. I don't know if the wood wedges would do that, if there is contact I imagine they might.
Doug and Cheryl
Old 05-20-2016, 09:54 AM   #33
1967 26' Overlander
Spartanburg , South Carolina
Originally Posted by John Oliver View Post
Thanks for all the input! Yes, my Soverign does have the grab handle and like others, I have used a series of different "wooden wedges" thru grab handle to keep door shut. I was hoping to find something a bit more craftsman like than a cedar wedge - although the wedge performs flawlessly !!! ( KISS ). Maybe I should leave well enough alone ...As yet. I have been unable to open files which have the prototype wooden latch. Will keep trying
When I started camping in our '67 25 years ago I would drive off then wonder if I had remembered to turn the dead bolt. Since I could not see it in the rear view mirror I had to stop to check. Since putting a bright colored bungee cord around the outside door knob and hooking it to the grab handle, I often still look in the RH mirror and can see the bungee in place.
Jacob D is offline   Reply With Quote
Old 05-29-2016, 04:00 PM   #34
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Clever idea. Thank you for sharing!
Dingo Girl is offline   Reply With Quote
Old 05-31-2016, 09:49 AM   #35
"Sassyfras"
oledawg's Avatar
1994 30' Excella
Winston-Salem , North Carolina
Trust me, the door will come open under certain circumstances even with the lock and deadbolt engaged. Cost me over $3,000 to replace the door when it opened going down the highway. I religiously use the notched piece of wood in the door handle now. It is foolproof 😎
Raconteur, Bon Vivant, Curmudgeon, and other depending on Susan's mood at the time...Retired, so don't ask me to do a damn thing
oledawg is offline   Reply With Quote
Securing Door While Traveling bimpy Doors & Locks 25 03-17-2015 03:54 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Entry door flew open while going down highway Boondocker Doors & Locks 27 10-01-2011 09:12 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
Lunar Eclipse underway Boondocker Off Topic Forum 4 03-05-2007 11:26 AM
