Old 05-18-2016, 04:44 PM   #15
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I see in the photos that you have a deadbolt in addition to the regular door latch. Underway, I always use the deadbolt and have never had a problem.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 05-18-2016, 05:43 PM   #16
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'd like a copy of the template, if you still have it!
Thanks!
Originally Posted by centennialman View Post
Here is the link for the wooden doohickie thingy. It worked well on my 1966 Airstream. http://www.airstreamcentral.com/arti...tch/Page1.html
I may still have the template in a file if anyone wants a copy. I spray painted mine gray.
Old 05-18-2016, 06:11 PM   #17
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I have to give credit to Freshair for the design of the wooden door block. He sent me a template 10 years ago and I believe he is the one on the link I posted earlier. I don't believe he would mind if it's shared since he posted the dimensions etc... on the link. If anyone wants a copy of my template, please send me a private message with the address and I will get it mailed out to you right away.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 05-18-2016, 07:03 PM   #18
Long Island , New York
Thanks Peter....I am curious to see if his trailer has a grab handle just to the side of the door or not. My 1966 Airstream had a grab handle and I fashioned a wooden piece that slid into it and across the door for extra piece of mind in regards to the door flying open.
When I bought my FC 20 this year the first thing I pondered was how I could make the door more secure from flying open. Haven't come up with any ideas yet.
Our 2014 FC20 does have a grab handle to the right of the door FYI. Thanks for the link to the wooden door safety piece.
OTRA15 is online now   Reply With Quote
Old 05-18-2016, 09:26 PM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
With the dead bolt in place I seriously doubt any Airstream door would come open. Maybe something unforeseen would happen, a really big bump, someone forgets to close it tight.
So we went to the hardware store and bought a small rubber door stop, and a little loop bungee. Drilled a hole in the tall end of the door stop and put the bungee through it. Then when traveling we loop the bungee to the grab handle and push it under the grab handle towards the door so it blocks the door from coming open. When we go inside we pull out the stop and let it dangle from the grab handle as a reminder to put it back in place when hitting the road again.
Doug and Cheryl
Old 05-19-2016, 07:54 AM   #20
Oldsalt47
John Oliver's Avatar
1985 31' Sovereign
Severna Park , Maryland
Door latch
Thanks for all the input! Yes, my Soverign does have the grab handle and like others, I have used a series of different "wooden wedges" thru grab handle to keep door shut. I was hoping to find something a bit more craftsman like than a cedar wedge - although the wedge performs flawlessly !!! ( KISS ). Maybe I should leave well enough alone ...As yet. I have been unable to open files which have the prototype wooden latch. Will keep trying
John Oliver is offline   Reply With Quote
Old 05-19-2016, 08:12 AM   #21
I like the design from Freshair. You slide it in place and give it a slight twist and it basically locks into position and doesn't come out while you are going down the road.
Old 05-19-2016, 10:20 AM   #22
LABTOPIA
labtopia's Avatar
1958 22' Caravanner
Atlanta , Georgia
I've got a 58 caravanner and the door will definitely flex and open when underway. I've got a strap latch that i lock with a padlock. I also leave the lock on when it's unlatched so there's no way someone can 'lock' me in. on the inside i have a big slide bolt for security when i'm inside.
dave
Dave Ballard - Full Time Airstreamer WBCCI #4276
http://180sqft.drinkertoys.com/ READ MY AIRSTREAM BLOG
Electric Unicycle Rider (SBU)
labtopia is offline   Reply With Quote
Old 05-19-2016, 10:29 AM   #23
Randakk's Avatar
2015 23' FB Flying Cloud
Pinehurst , North Carolina
2 simple "Eye" bolts + a heavy-duty Zip-tie.
Randall Washington (Randakk)
Pinehurst, NC
2015 Flying Cloud 23FB
2015 Chevrolet Silverado 1500 WT 4WD
www.randakks.com
Randakk is offline   Reply With Quote
Old 05-19-2016, 10:54 AM   #24
1965 17' Caravel
Preeceville , Saskatchewan
I have used the wooden keeper on a '65 Caravel for several years and it works great.
Peace of mind is very important.
sockeyeron is offline   Reply With Quote
Old 05-19-2016, 12:55 PM   #25
1993 30' Excella
Lovettsville , Virginia
We were warned about the door coming open. Didn't believe it till it happened to ME!!! Last year after stopping for lunch, I locked the trailer and got back on the road. within a half mile of getting on the interstate I looked back to see the door open and something fly out. The interstate was very bumpy and I had just gotten up to speed. We have the dead bolt lock and the door still came open. Jim was able to repair the door after reading the on line posting here about door repair ( big thanks to all who posted, esp. the photos). Door is not flush but it works.
Jim did make one of the wooden door latches and we have been using that for the last year. He had to modify it a bit to fit the trailer.
Sabre30 is offline   Reply With Quote
Old 05-19-2016, 02:04 PM   #26
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Easy door secure solution
The PO of our Argosy was the parts guy at an RV place that works on a lot of Airstreams and his solution was to drill a hole in the drip rail at the top of the door and put a spring clip thru it. Door will not come open, easy to install. That is the last thing we do when we lock the door getting on the road is install the clip.
rvb is offline   Reply With Quote
Old 05-19-2016, 04:12 PM   #27
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
door stop
Name:	20160519_130729 door stop2.jpg
Name:	20160519_130750 door stop.jpg
I couldn't figure out how to reorient these pictures. They need a 90 degree flip so they are showing properly.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 05-19-2016, 05:54 PM   #28
2008 28' Safari S/O
Poulsbo , Washington
I installed a Home Depot deadbolt on my suicide door which did pop open underway. I had to mount it on the body with the bolt going into the door as the locket was too thick to mount in the door.
shinydimples is offline   Reply With Quote
Securing Door While Traveling bimpy Doors & Locks 25 03-17-2015 03:54 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Entry door flew open while going down highway Boondocker Doors & Locks 27 10-01-2011 09:12 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
Lunar Eclipse underway Boondocker Off Topic Forum 4 03-05-2007 11:26 AM
