03-15-2015, 05:43 PM
1974 29' Ambassador
1976 25' Caravanner
trenton
, Missouri
Securing Door While Traveling
A couple of years ago I saw on the forums a guy who had fashioned a small block of wood which fit into the exterior grab handle and lapped over the door to keep it secure while towing. I can't seem to find this anywhere on the forums now. I"m really tired of the old bungee cord across the door. Please help if you can thanks
03-15-2015, 06:00 PM
1968 24' Tradewind
Oxford,
, Mississippi
I have a good pic of one that I found on the forums several years ago.
I made one and use it every time I pull my 68. Send me a PMwith you email and I'll send you a pic. I can't figure out how to post a pic here.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
03-15-2015, 06:41 PM
Biloxi
, Mississippi
Here,
MICHAEL
03-15-2015, 07:40 PM
2019 27' Flying Cloud
Kansas City
, Missouri
The one I remember had a locking pin. This one is better looking.
Piggy Bank
03-15-2015, 09:24 PM
Biloxi
, Mississippi
MICHAEL
03-16-2015, 12:44 PM
1981 31' Excella II
Richmond
Locking door handle
Camping world has a great handle that has a three position base, which allows it to be used as an assist handle in the middle position, or flat against the door to secure the door in transit.
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
03-16-2015, 01:02 PM
2012 25' Flying Cloud
Battle Lake
We just use a rubber door stop wedge slipped through the grab handle, drilled a hole in it and attached one of those little bungee cords with the red ball on it to keep it on the handle when camped. Works like post #3 above, always at hand.
cheryl k
03-16-2015, 01:46 PM
1972 29' Ambassador
Boynton Beach
Originally Posted by AWCHIEF
Here,
I wonder why that deadbolt is mounted backwards? And why a deadbolt isn't a great way to keep a door from flying open (or your stuff from "flying away").
I'm very confused here!
03-16-2015, 02:26 PM
1989 25' Excella
Torrington
, Wyoming
I,too, am wondering about this. Does this mean the deadbolt isn't to be trusted on the road? Is this just extra security?
03-16-2015, 02:57 PM
1966 22' Safari
Hilltop Lakes
Easy to make, work great
I made three of them while I was at it. Easy to enlarge the plan view photo to the right size on a copier. Cut it out of scrap plywood with a jig saw. Paint it as you choose.
I keep ours in the window as shown. It's in plain sight when you're closing the door. Of course, we also put it on our checklist.
03-16-2015, 04:46 PM
Battle Lake
Roadways can be rough, trailers flex, doors can come open no matter which way they swing. It's an extra precaution some of us use, not a requirement.
cheryl k
03-16-2015, 05:05 PM
2008 27' International FB
Venice
Here,
Thanks for sharing!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
03-16-2015, 05:47 PM
1978 25' Tradewind
Metro Phoenix
Subscribing. Thanks, y'all!
03-16-2015, 07:53 PM
1967 22' Safari
West Fork
, Arkansas
VTS backwards deadbolt
This shows how we think we have solved the issue with door coming open while on the road as well as securing the door from either inside or outside.
VTS has a deadbolt adapted with an extended bolt so that penetrations through frame or door are fairly small. It fits in the jamb rather than the door and since we had the interior skins off, it was reasonably easy to install but still not easy. We added a block of wood to the jamb to give it more substance.
I know the door exterior looks like hammered dog poop in this pic but it is much better now that we have made progress cleaning it up.
03-16-2015, 08:34 PM
Durango
This must be more of a problem with older Airstreams.
My 2015 Airstream door fits tight as a drum and the dead bolt engages at least an inch into the main frame. There is no way that door would open accidentally on a rough road.
03-16-2015, 08:50 PM
Dazed and Confused
Hillsburgh
, Ontario
You just Murphy'd yourself. What can seem improbable or even impossible still has probable or possible within the words. Never say never and pray it never happens to you.
Murphy may bite you in other ways. The Airstream Gods are a fickle bunch.
Cheers
Tony
03-16-2015, 09:10 PM
Durango
Cheers
Tony
Thanks for the warning, luckily I'm not worried about Murphy in this case. If my door comes open due to a rough road when I have it bolted then I will have a lot more damage to worry about than just a suicide door.
03-16-2015, 09:11 PM
2007 22' International CCD
Corona
Murphy was an optimist. Be warned.
03-17-2015, 08:00 AM
2008 27' Safari FB SE
Pfafftown
, North Carolina
Attached is a PDF with a scale drawing of the wood door lock block which you can use for a template. I intend to make one with 3/4" plywood. You may need to adjust for your particular installation. Easy to cut with a bandsaw, jigsaw or even good scrollsaw with the right blade.
AS Door Lock Pattern.pdf
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2022 Ford F350 King Ranch, 6.7 Diesel, 4X4 (Big Red)
WBCCI 3823 - Unit 12 | AIR 48265
03-17-2015, 08:27 AM
1966 24' Tradewind
Placerville
I made several extra of these and have given some out at rallies. Hopefully those of you making your own, after all you'll have plenty of material left, and make them available as you camp. It's been several years since I posted that 'how too' article and since have noticed that many later Airstream models with doorway grips could adapt versions for their use. Just trace the shape to cardboard and trim to fit. My lock and 'travel' dead bolt should be adequate for my Trade Wind but this little piece of wood sure feels and looks very secure.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
