Old 03-16-2015, 08:34 PM   #15
Durango , Colorado
This must be more of a problem with older Airstreams.
My 2015 Airstream door fits tight as a drum and the dead bolt engages at least an inch into the main frame. There is no way that door would open accidentally on a rough road.
RVDreamer is offline   Reply With Quote
Old 03-16-2015, 08:50 PM   #16
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
You just Murphy'd yourself. What can seem improbable or even impossible still has probable or possible within the words. Never say never and pray it never happens to you.
Murphy may bite you in other ways. The Airstream Gods are a fickle bunch.
Cheers
Tony
Old 03-16-2015, 09:10 PM   #17
Durango , Colorado
Cheers
Tony
Thanks for the warning, luckily I'm not worried about Murphy in this case. If my door comes open due to a rough road when I have it bolted then I will have a lot more damage to worry about than just a suicide door.
Old 03-16-2015, 09:11 PM   #18
2007 22' International CCD
Murphy was an optimist. Be warned.
KE4GNK/AE
Old 03-17-2015, 08:00 AM   #19
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Attached is a PDF with a scale drawing of the wood door lock block which you can use for a template. I intend to make one with 3/4" plywood. You may need to adjust for your particular installation. Easy to cut with a bandsaw, jigsaw or even good scrollsaw with the right blade.
AS Door Lock Pattern.pdf
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 03-17-2015, 08:27 AM   #20
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I made several extra of these and have given some out at rallies. Hopefully those of you making your own, after all you'll have plenty of material left, and make them available as you camp. It's been several years since I posted that 'how too' article and since have noticed that many later Airstream models with doorway grips could adapt versions for their use. Just trace the shape to cardboard and trim to fit. My lock and 'travel' dead bolt should be adequate for my Trade Wind but this little piece of wood sure feels and looks very secure.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-17-2015, 08:41 AM   #21
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Whats old is now new again. I have had one of these on 2 Airstream going back about 20 years. It was not a new devise when I first saw it on the Old VAC site. Tried and true and does the job.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-17-2015, 11:35 AM   #22
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I'm thinking this may be a problem with older trailers. I lock the door latch lock and the deadbolt both. I have never had the door come open, but many times it feels like it has come unlatched, but did not open. I would say that it is due to the motion of the trailer, but it happens from time to time while parked. Could wind cause enough flex in a parked trailer to cause the door to come unlatched? I guess this is part of the reason for the deadbolt.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-17-2015, 11:53 AM   #23
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
We have two vintage streams and have made these door securers based on the directions presented here. They DO work and were easy to make.
We have had our door in door fly open once on a bumpy trip where our inner latches had worked themselves loose/up. It was slow speeds, POURING rain, freeway and for a few minutes could not figure out why the enthusiastic folks in the lane next to us kept waving and screaming.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 03-17-2015, 12:25 PM   #24
Durango , Colorado
Agreed, I think it must be older trailers because with my deadbolt locked on my 2015 door it is not coming open due to a bumpy road. I would not trust just the latch but the dead bolt enters the door a good inch. A crowbar could possibly pry it open but not flexure of the frame.
I have a 27FB so the door is not a suicide door. It faces the other direction and wind from driving would close the door rather than open the door.
Old 03-17-2015, 12:33 PM   #25
I have a 22FB with the suicide door. The worst bit is that I can't open the forward dinette window at all because the door will hit it instantly with predictable results. Nice view out that window, but no ventilation. Fixed glass would have made more sense there.
I'll be making a wedge. Just because the door has never popped doesn't mean it won't.
KE4GNK/AE
Old 03-17-2015, 03:54 PM   #26
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
Thanks to all who responded. I just got around to checking replies today
bimpy is offline   Reply With Quote
Making a living while traveling yukionna On The Road... 17 04-23-2013 11:47 PM
New 27FB bathroom door opens while traveling motozen Interior Restoration Forum 4 11-14-2011 09:17 AM
Refrigerator on while traveling? electrodx Member Introductions 17 11-13-2007 03:59 PM
Do you use your LP refrig while traveling? John Community Polls 19 07-23-2005 09:28 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
