04-05-2007, 07:29 AM
Devils Lake
, North Dakota
Screen Door Thingy
Just got my 1973 Argosy 26'. I see the plastic thingy that slides to cover the area where the handle to the main door handle is, is gone. Wish I had a name for it. But it slides to cover the hole when using the screen door by itself. Can these be found?? Or fabricated??
04-05-2007, 07:36 AM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Airstream Store
A dealer should be able to help you. Otherwise, try the Airsteam store, I just bought a thingy from them. The plastic part that fits our trailer apparently fits a wide variety of years. The part the Airstream store sells is oversize then you cut it down to size. A Dremel tool, or a heavy duty set of shears may work.
You may also want/need the fuzzy stuff that is applied to the opening of the thingy to keep bugs out when using the screen door. The Airsteam store also has the fuzzy stuff.
There are other posts on the forum that address the thingy and the fuzzy stuff.
Lucius
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
04-05-2007, 07:40 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Measure the width you need but I have used the ones from an SOB, just have to cut them down a bit. Razor knife and straight edge works, as does a pair of tin snips.
Aaron
WBCCI #XXXX AIR #2495
04-05-2007, 09:26 PM
Devils Lake
, North Dakota
Aaron
My concept of SOB and yours are different I am afraid. What is SOB in your meaning???
04-05-2007, 09:33 PM
1977 Argosy Minuet 6.0 Metre
Colorado Springs
I may be albe to help here. That would be Some Other Brand.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
04-06-2007, 03:33 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Or Square Old Box...but it you have to work on them....
Aaron
04-06-2007, 04:22 AM
1993 34' Excella
Estancia
, New Mexico
You can get the thingies and fuzzies from Inland RV
04-07-2007, 11:38 AM
Corona
That "thingy" is called a screen door bug guard.
Part # 84119 works for your year trailer.
07-07-2007, 08:06 PM
1975 23' Safari
1978 31' Excella 500
Franklin
, Indiana
Here are a couple of pics from replacing the screen door bug guard on our '75 Safari. The Airstream Store at the WBCCI Internation in Perry, GA even threw in some fuzzy seal for free!
The old one was made of translucent plastic and pretty thin. This new one is significantly thicker--almost too thick to slide in the small channel. I ended up trimming the top and bottom evenly to fit the space (it's an even 6" on my door btw) and using the dremmel to 'thin' the edges to make it easier to slide.
The fuzzy seal is attached to both vertical ends with superglue. I put the little 'handle' toward the hinge side so that if the screen door is accidently closed with the bug guard in the way the door handle will not pop it out. It looks kinda backwards this way, but I think it makes more sense that way....
Dallas Peak, MD 'That 70's Guy!'
VAC Past President
WBCCI #8481
07-09-2007, 09:31 AM
Corona
Your photo shows the only bug guard that Airstream used in the 1970 to 1977 models.
The clear plastic one that you had was a "home brew."
07-28-2007, 06:05 PM
I just got the screen door bug guard and cut it down using a hacksaw. It worked fine. (didn't have dremel....have to put it on my christmas lists) And never attached a fuzzy to that. Still works fine, and fits well. I used the fuzzy for around window screen guides. Wow!!! Streamin in Cape may with lights on and no mosquitos!!! quite the experience! Whateverr you do, I'm sure you will enjoy your improvement!
It's the rivets!!!!!
