Old 07-18-2012, 08:50 AM   #1
angellhill's Avatar
1978 Argosy Minuet 6.7 Metre
Burlington Flats , New York
Screen door sliding plastic panel, bug guard
I recently got a 78 Argosy Minuet 6.7 Metre. THe sliding panel that keeps the bugs out when using the screen door/lets the outer door handle fit when closed, is broken. I looked online and found a replacement at Inland RV. It was $18.25 and you have to have a $25 minimum order. The shipping was high, too. Does anyone know of another source for this part? Thank you.
angellhill is offline   Reply With Quote
Old 07-18-2012, 08:57 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Those are a pretty standard item. I know that ODM has them. You could try Camping World too. They need to be trimmed down a bit to fit the AS doors.
Aaron
WBCCI #XXXX AIR #2495
Old 07-18-2012, 10:24 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I made one out of a piece of fiberglass sheet. It isn't concaved for the exterior door handle clearance. But all that means is that the little door has to be open to close the exterior door. Not a big deal.
Old 07-18-2012, 07:26 PM   #4
angellhill's Avatar
Thank you both for the great ideas. Since my husband is handy, maybe he'll give it a shot. If not, we'll try ODM.
Old 07-18-2012, 08:02 PM   #5
1977 Argosy 24
Milltown , Wisconsin
Do you flex the plastic to get it to fit into the grooves in the door frame, or is there another trick?
ventport is offline   Reply With Quote
Old 07-18-2012, 08:48 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You flex the plastic or fiberglass to install it. If I remember correctly measure the opening top to bottom then add 3/8" to that dimension. Of course the horizontal direction is not that critical, it just has to cover the opening with some overlap when closed. There are some photos that show the small door in one of the threads about screen door latches. It is in the Argosy trailer forum I believe. Look for my handle.
