Old 06-03-2009, 03:59 PM   #1
Utahgoldrup's Avatar
1991 25' Excella
2005 16' International CCD
Salt Lake City , Utah
Screen Door - Replacing Foam Gasket
I need to replace the foam gasket going around the screen door of our Airstream (1991 25ft. Excella), I purchased the new foam/gasket from Inland RV and it has an adheasive backing on it, can I just take off the protective strip and stick the foam/gasket to the screen door where the old one was or do I need to use any type of adheasive?
Utahgoldrup is offline   Reply With Quote
Old 06-03-2009, 05:58 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
gasket
Even Inland recommends using the 3M black adhesive. Thats what I did....you know....belts and suspenders.
Old 06-03-2009, 06:06 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Are you describing the black closed cell foam door gasket or an open cell grey foam gasket. I am not sure if using 3m Super Weatherstip Adhesive is a good idea on the open cell foam gasket which is more of a seal than a gasket designed to keep out the weather.
Old 06-04-2009, 08:36 AM   #4
1991 25' Excella
This is the open cell grey foam gasket (thanks for a much better description than I could come up with). That is part of my concern, would the 3M Super Adhesive be too much and possbily get all gummed up in this foam gasket? I have some of this adhesive and will be using it to replace the gaskets around the windows and the main door. I just wasn't sure if using the sticky side of the grey foam gasket is enough to hold it or not.
Old 06-04-2009, 11:23 AM   #5
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I just used it with the self-stick on the gasket that comes with it. I redid all my gaskets last year. The screen door is hanging in there just fine. I think that open cell gasket wears out faster than the rubber on the windows & doors and will need to be replaced more often. It seems to deteriorate & fall apart after a number of years. Much easier to remove w/o gasket glue!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-04-2009, 11:35 AM   #6
Adhesive is not to be used to install a new screen door gasket.
Simply peel the protective film, from the gasket, and install it.
But first make sure the screen door frame is clean.
Old 06-04-2009, 01:52 PM   #7
1991 25' Excella
Smile
Sweet!! Thanks for the feedback and comments, we are heading out tomorrow and that is at the top of my list to get done and I wanted it to be done right!!
Old 06-04-2009, 02:32 PM   #8
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
oops
I used the 3M with the rubber window gaskets.....I don't even own a screen door.
Screen door gasket source? 63air Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 02-18-2008 02:00 PM
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
Replacing Window Screen on 1954 Liner Lookinghard Windows & Screens 3 09-20-2005 11:03 AM
Need screen door gasket for '56 Flying Cloud cdmagda Doors & Locks 0 06-22-2005 08:07 AM
replacing window gasket silverlassie Windows & Screens 4 03-07-2004 07:41 PM
