Old 11-11-2015, 03:03 PM   #1
1998 30' Excella 1000
Livingston , Texas
Screen Door Panel Remove/Replace?
The sliding fiberglass(?) panel that moves to provide access to the latch handle on the front door, rattles a lot when we close the door. I was going to try to add something to it to make it more snug, but it appears that it was installed in the track before the aluminum frame was welded up. If this was ever needed to be replaced, I'm not sure how it could be done. Has anyone ever encountered this problem?
Siegmann is offline   Reply With Quote
Old 11-11-2015, 03:13 PM   #2
2010 25' FB Flying Cloud
Davenport , Iowa
There is a CLEAR replacement that is available, but for SOB's. The clear ones are too thick for the AS. I have tried.
Airtandem is offline   Reply With Quote
Old 11-11-2015, 03:33 PM   #3
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
That panel flexes just enough to be removed. You can pull in the left center when the panel is opened a little. Camping World should have a universal replacement that may need trimming for your door.
Dennis
dennis3751 is offline   Reply With Quote
Old 11-11-2015, 03:45 PM   #4
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Out
Airstream Screen Door 11.11.15 by Tommie Lauer, on Flickr
In
Airstream Screen Door 11.11.15-2 by Tommie Lauer, on Flickr
And, while I am here, putting a different catch on my screen door means if I am carry something, no need to work the difficult latch mechanism, just push. Add the ball catch, remove the black plastic catch plate for the plastic sliding catch.
Airstream Screen Door 11.11.15-3 by Tommie Lauer, on Flickr
Airstream Screen Door 11.11.15-4 by Tommie Lauer, on Flickr
And, there you have it. Admittedly, it requires some effort to remove the sliding plastic door, but can be done and replaced easily.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 11-11-2015, 03:55 PM   #5
2006 30' Safari
Divide , Colorado
Curious, where did you purchase the ball latch?
Thanx in advance.
Rod
gwydir is offline   Reply With Quote
Old 11-11-2015, 04:07 PM   #6
Msmoto's Avatar
2007 25' Safari
Images: 135
I think it was Lowes Home Improvement
Old 11-11-2015, 06:21 PM   #7
Livingston , Texas
My panel seemed pretty stiff, and I was afraid to crack/break it. Good to know it will come out. Thanks-
Oh, also, nice mod on that pesky catch.
Old 11-13-2015, 03:54 PM   #8
Msmoto's Avatar
2007 25' Safari
Images: 135
More....
And I also put a ball catch on the screen/main door connection. This really makes it nice as it relieves the nasty job of pulling the little black thing to get the screen closed when both doors are open. I now simply reach around and pull the screen off the main door and relatch onto the frame.
And, this is one of the best changes I have made!
Old 11-13-2015, 07:26 PM   #9
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Would you mind posting a pic of the ball catch connecting the screen door to the main door? I love the idea and would appreciate seeing the placement. Thanks!
Regards,
Joe
jayseejay is online now   Reply With Quote
Old 11-14-2015, 03:21 PM   #10
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Regards,
Joe
I too am interested in this, sounds like a great mod
Gary
Castaway is offline   Reply With Quote
Old 11-16-2015, 10:06 AM   #11
Msmoto's Avatar
2007 25' Safari
Images: 135
Latch
Airstream Latch 11.16.15-2 by Tommie Lauer, on Flickr
Airstream Latch 11.16.15 by Tommie Lauer, on Flickr
Please note, the small piece on the main door is not exactly level, apparently due to my imprecise drilling techniques....but all works well and this makes the convenience so much better than that *&^&^& latch installed at the factory.
Having said all this, there may be times in extremely windy conditions that more security is required, and I will no doubt place an interior latch on the screen door for added security....TBD
How to remove door to remove frig Silver84 Refrigerators 6 07-06-2015 01:32 PM
Remove center aluminum panel from screen door bunni Doors & Locks 0 04-03-2015 11:34 AM
Screen Door Aluminum Center Panel Moves KJRitchie Doors & Locks 1 04-03-2015 08:17 AM
Screen door sliding plastic panel, bug guard angellhill Doors & Locks 5 07-18-2012 08:48 PM
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
