Old 12-20-2006, 05:54 PM   #1
1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
Angry Screen door broken
Does anyone have available the part pictured? Some kids broke in and wrecked some stuff. It goes on the screen door and slides to cover the access to the entry door handle.
Name:	door piece.jpg
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 12-20-2006, 06:07 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I just ordered one from Outof doors mart
'77 Sovereign Intl 31' CB
Old 12-20-2006, 06:08 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
You can get those at any Airstream dealer or the factory store.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 12-20-2006, 06:43 PM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
I was noticing that you are missing the door latch.Did yours break? mine broke and I'm looking for a replacement. Either that or weld up the broken innards.So have you any spares? Thanks Tim
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 12-20-2006, 07:09 PM   #5
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
try the classifieds on the forum or look for balgrn in the members list he had a argosy for parts.same slide as yours..
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 12-20-2006, 09:46 PM   #6
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
It isn't cheap...
For a pretty simple piece of molded plastic, they're expensive... Our Airstream dealer marked it at $24.95... Old or used ones could be pretty brittle and not last long, as the plastic has a useful life.. Very reminiscent of royalite trim used in some aircraft...
Inland RV sells it as Part 84119 on sale at $15.75...
It requires trimming (very carefully, as over-trimming renders it useless..) and looks much better if painted before assembly in gray to match rest of screen door...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 12-20-2006, 11:03 PM   #7
1983 34' Limited
Las Vegas , Nevada
They broke mine latch too. My latch was not original and was put in over a plate so I think I can take care of that fairly easily.
Thanks for the help. I might be going not too far away from inland mid January.
Old 12-21-2006, 06:55 AM   #8
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
I went for the cheapest solution which you may consider in a pinch: a simple scrap piece of aluminum with a finger hole in it. It's not ideal of course because you need to remember to slide it open before closing the main door or the door handle bends it when they collide. I have a picture in my web log under May. Sheet styrene would work too or if you think about it you may be able to engineer something better...
Good luck,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 12-21-2006, 09:22 AM   #9
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
another method
do this with a chunk of acrylic, get it from a plastic supply place. theres gotta be one in Reno! The pics pretty much sum it up.The roller catch on the plastic releases when you close the door, then the plastic door swings free, then you secure it with the little knobie homemade keeper.A project to keep you busy in your retirement.
Name:	86 Excella 094.jpg
ID:	29989   Click image for larger version
Name:	86 Excella 095.jpg
Name:	86 Excella 096.jpg
ID:	29991   Click image for larger version
Name:	86 Excella 097.jpg
www.popasmoke.com
YETI ( 65 Quart )
Old 12-21-2006, 01:04 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
dmadam,
Those are pretty generic depending on the year of your Airstream the current ones available at your local RV dealer should fit, if not they can be cut to size. Take the pieces of the old one with you for comparison as they come in several different configurations.
Aaron
WBCCI #XXXX AIR #2495
Old 12-22-2006, 05:57 PM   #11
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
ONE ON EBAY NOW -
eBay Motors: Airstream Plastic Slide For Screen Door 1980's (item 160064089519 end time Dec-22-06 19:00:00 PST)
May be too late to read this - 2 hours left.
Good Luck
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-09-2007, 07:44 PM   #12
LookingThroughALens
aturner4u's Avatar
1976 Argosy 24
Marietta , Georgia
Images: 20
Screen Door Latch - Inside Needed
We need to find the latch that holds the screen door closed to the frame (on the inside). Our dog has figured out how to push open the makeshift roller thing someone has installed. I took a portion of a photo someone posted of what it should look like. We have the white plastic part rivited to the door frame but are missing the latch part. Any idea where we can get it or something that will work? The InlandRV latches look like our outside latch, not something that will work with the white thing rivited to the door frame. If anyone has a better photo of what it SHOULD look like that would be helpful as well.
Thanks.
Anne
In nature, light creates the color. In the picture, color creates the light. --- Hans Hofmann
aturner4u is offline   Reply With Quote
Old 09-09-2007, 08:41 PM   #13
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The Latch you Need
Anne, the black portion of the latch is the part used to hold the door closed. You have to buy the whole thing either from Inland or from Airstream. I've also seen them on Ebay.
Old 09-09-2007, 08:57 PM   #14
StingrayL82's Avatar
San Angelo , Texas
Images: 37
There are still Airstream dealers out there who sell that part; you just have to hunt for it, like I did for my bathroom light cover. Don't let someone tell you to replace it with something new and live with it.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Wooden screen door eraffety Airstream Motorhome Forums 7 06-20-2011 07:46 PM
Screen Replacement, Alum or Fibreglass? Road Ruler Windows & Screens 4 10-15-2002 08:44 AM
Screen door for 310 MH kzener40 Airstream Motorhome Forums 1 06-14-2002 10:21 AM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
