Old 12-13-2010, 04:38 PM   #1
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
RV Lock
Has any one tried the remote controlled lock advertised in the current in issue of Trailer Life?
jfowler218 is offline   Reply With Quote
Old 12-13-2010, 04:53 PM   #2
dznf0g's Avatar
Oswego , Illinois
No, just saw it in today's mail. It would be nice if they had a silver one!
Old 12-13-2010, 11:59 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, no I wouldn't even consider this new lock; It has the tongue on it like a common house door latch. My Airstream latch has cogs and a striker plate similar to what is used on a modern car.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-15-2010, 06:53 PM   #4
1976 31' Sovereign
Pheba , Mississippi
I'm restoring 76' 31ft. sovreign I have just purchased, it does not have any keys to any of the doors. Where can I find some without calling a locksmith?
barrynheath is offline   Reply With Quote
Old 12-15-2010, 07:11 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The door latch/lock on the newer Airstreams is what we call "bear claw", like the ones on later cars, starting in the late 60s.
We buy after market latches of this type for use on Street Rods to replace the old, and usually worn out, spring loaded latches used on old cars.
The ones we get are small, and will fit the thin door frames of Airstreams. That may very well be what they are using at the factory.
Electric actuators are also available which are thin enough to fit inside an Airstream door. These can be triggered by remote. You don't even have to run wires into the doors. Contacts are made that fit into the door jamb and "make" when the door is closed. These can be made to open and to lock/unlock using a remote. They also work with a handle and key.
There is some pretty slick stuff out there.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-15-2010, 08:22 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Just found small bear claw latches with built-in actuators with remote that should fit in an Airstream door.
That would be fun.
Got a new Lock michael13 Doors & Locks 3 11-06-2009 08:06 AM
How does this lock? bullydogsmom Cabinets, Counter Tops & Furnishings 7 06-19-2009 10:05 AM
how does this lock go together? BGS Doors & Locks 0 05-01-2008 02:42 PM
Help with lock please? centennialman Doors & Locks 10 07-06-2006 05:45 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
