Old 09-02-2002, 09:36 AM   #1
Road Ruler's Avatar
Images: 38
Question Rubber Door Seal Replacement
Hello Folks
I purchased new door seal for the outside door of our safari.
It appears the seal is glueed on. Is there a proper adhesive for this job???
Thnxs in advance.
Old 09-02-2002, 09:46 AM   #2
mkeith54's Avatar
1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
Wayne,
My personal choices would be 3M Scotch grip Industrial Adhesive # 4799 or 3m Automotive weatherstip adhesive, both are about the same formula as far as I can tell. You should be able to get the adhesive at any large auto parts house that deals in paint and body repair items.
Mike
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
mkeith54 is offline   Reply With Quote
Old 09-02-2002, 09:54 AM   #3
Road Ruler's Avatar
Images: 38
door seal
Thnxs Mike..
Will this adhesive bond on contact or will it have to be secured for a bit?
Old 09-02-2002, 10:18 AM   #4
LOST , Hawaii
Once you put weatherstrip adhesive on it has to sit for a minute or two before joining the pieces. When you put the gasket on the door it is a contact adhesive, have it right.
John
74Argosy24MH is offline   Reply With Quote
Old 09-02-2002, 10:41 AM   #5
mkeith54's Avatar
1976 26' Argosy 26
They are both contact cements. I smear the glue on both and wait until they set up and then stick them together.
Mike
Mike Keith
75 Argosy 26'
Old 01-01-2003, 06:36 PM   #6
rscafuto's Avatar
Question
Is the weatherstrip made for the Airstream door? I need one for my '76. Can you tell me where you got the weatherstrip?
Thanks, Richard
rscafuto is offline   Reply With Quote
Old 01-01-2003, 08:01 PM   #7
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Richard,
I purchased the door seal for my 76 MH from Ace Fogdall in Iowa.
It came with a adhesive foam tape pre-applied. I pulled the old stuff off of the door and using a dremel tool with a sanding wheel stripped the old glue off and got to clean alum. Then it was just peel and stick. I put it on 5 months ago and have not had any problems with adhesion.
They sell it by the foot, so measure and get enough to make a mistake. Florence or Christy can help you and they are at 800-747-0747.
They also have the insert for the interior trim in the bathroom, kitchen and lounge if you need it. It was originally ivory in color, but tends to fade to a tan/brown color.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Sofa/Sleeper replacement 69Ambassador Upholstery, Blinds, Walls & Interior Finishes 0 02-21-2004 07:00 PM
Replacement air bags on the rear suspension? TRAPEZE Airstream Motorhome Forums 1 03-09-2003 08:42 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
