So the previous owner of my unit must have been impatient because when they took the door knob off the outside door, instead of disassembling it, they cut the aluminum around it out. My guess is that the handle was rusted pretty bad and it was difficult to get the screws out or something, but either way, now I am left with a big square hole that I need to put a round handle into. Has anyone ever seen this before, or experienced something similar. I want to repair it so that it still looks good when its done (I dont just want it to look like a patch job). Does anyone have any ideas of how to fix it without replacing the whole door? Thank you all for your sage advice.
photocodo
Quite a butcher job. It looks like you'll need to patch as a minimum, or depending on the conditon of the surrounding skin you may be better off re-skinning the door.
Were any structural elements cut?
Regards,
Kevin
__________________ Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
there was no structural damage that i can see. I did get a message from inland RV saying that the square hole was for an L-100 lock and the bottom hole is for the dead bolt. Does this make sense. What do you think? does anyone know the dimensions for the hole for the L-100 lock?
thanks
The L-100 lock uses a round interior handle, which doesn't break.
The L-200 lock is the same lock, except it has a horizontal handle on the inside, which is famous for breaking, since you must pull on it to close the door.
That happens usually when new door gaskets are installed, which are essential to stopping water leaks at the door area.
Andy got back to you about the L-100 fitting the hole before I could.
Another question, do you have the deadbolt that goes in the lower holes & uses the lower striker pocket? If not, you will want to get one of those too. My Trade Wind doesn't have the deadbolt and I always wished it did. Plus, you need to fill those holes anyway. Really, the deadbolt adds a lot to the security.
__________________ Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties.Oscar Levant
The only Airstream deadbolt I have any experience with is in my 1983 Excella. It has the bolt that is thinner than a home deadbolt. I wasn't sure if he would need something Airstream specific for his.
I actually went to ace hardware and picked up a deadbolt for $12 that fits pretty well. It took me a little time to "shimmy" it into the door but overall it works well.
cody
