Old 11-13-2009, 10:40 AM   #15
Originally Posted by photocodo View Post
Will the Bargman L100 work for this unit because of the round hole on the inside of the door? or do I need to cut a square hole for the inside?
The L-100 should fit, but you may have to do a little trimming.
You also should replace the nylon striker pockets
Old 11-14-2009, 07:44 AM   #16
1964 24' Tradewind
Orlando , Florida
Thanks andy
I noticed that you have the striker pockets as well, very convenient. I appreciate all of your help
cody
photocodo is offline   Reply With Quote
Old 11-14-2009, 10:47 AM   #17
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Cody,
Andy got back to you about the L-100 fitting the hole before I could.
Another question, do you have the deadbolt that goes in the lower holes & uses the lower striker pocket? If not, you will want to get one of those too. My Trade Wind doesn't have the deadbolt and I always wished it did. Plus, you need to fill those holes anyway. Really, the deadbolt adds a lot to the security.
Vaughan
Old 11-14-2009, 12:37 PM   #18
Originally Posted by vswingfield View Post
Hi Cody,
Usually, you can get the dead bolt at Home Depot.
Old 11-14-2009, 02:04 PM   #19
1983 34' Excella
1967 24' Tradewind
Images: 32
Thanks Andy,
The only Airstream deadbolt I have any experience with is in my 1983 Excella. It has the bolt that is thinner than a home deadbolt. I wasn't sure if he would need something Airstream specific for his.
Vaughan
Old 11-15-2009, 08:40 AM   #20
1964 24' Tradewind
Orlando , Florida
I actually went to ace hardware and picked up a deadbolt for $12 that fits pretty well. It took me a little time to "shimmy" it into the door but overall it works well.
cody
Old 11-23-2009, 11:30 AM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Has anyone used the L200sp for a newer 70s or later trailer? The butcher job that was done on my trailer lock has been corrected with a patch, but I am not happy with the lock and would like to put on the vintage style. It now has a handle style home depot lock the p.o. put on.
I think the 200sp has a long enough bolt to reach through the frame correctly.
L200sp lock
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-23-2009, 11:41 AM   #22
L200sp lock
Sorry, but the L-200 striker bolt length is not long enough to go thru the cast metal door frame, and engage the striker pocket, that you have.
Old 11-23-2009, 11:46 AM   #23
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I see that, and tried one a friend has, but the 200SP model has a much longer striker bolt.
Bargman L-200SP SKU3330L [682399L]
Must be a special purpose model I guess.
AIR #005
retired!
Old 11-23-2009, 12:04 PM   #24
The L-100 and L-200 are the same except for the inside handle.
The L-100 has a round inside knob.
The L-200 has staright inside handle, that break when you slam the door. That's the # 1 reason most owners repalce them.
The L-100 Special is the same as the L-2oo special, except for the inside handle.
But, in either case, they are designed to work with the "cast metal" door frame.
Old 11-23-2009, 12:16 PM   #25
1983 34' Excella
1967 24' Tradewind
Images: 32
Somewhere in all my stuff I found one of the L-200 handles. I tried it on the door of my Trade Wind just to see how it worked compared to the knob. It was very difficult to operate through the screen door. I took it off immediately and put the interior knob (L-100) back on.
Vaughan
Old 11-23-2009, 03:51 PM   #26
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
How does the knob model work with the screen door? That is the main problem, the one we have sticks in too far for the slide. I could leave the slide back when I close the door but isn't it supposed to clear with the slide over it?
AIR #005
retired!
Old 11-23-2009, 03:54 PM   #27
1983 34' Excella
1967 24' Tradewind
Images: 32
No.
With the slide open, the knob protrudes through leaving you plenty of room for knuckles to clear the screen door. With the door closed, you don't need the slide shut anyway.
Vaughan
Old 11-23-2009, 03:58 PM   #28
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thanks. THis trailer originally would have had the flat on the outside lock, but the way it has been set up the round handle will work and look way better.
AIR #005
retired!
Round bars or square georgezink Hitches, Couplers & Balls 1 03-16-2009 11:06 PM
The Wheels Go Round and Round wheel interested Our Community 36 11-05-2008 03:59 PM
square bearings wigo All Squarestream Trailers 7 11-09-2007 06:10 PM
Square Stream aviontt All Squarestream Trailers 5 12-06-2003 05:09 PM
Square footage ? H-n-C Repairing/Replacing Floor &/or Frame 11 03-16-2003 06:43 PM
