Old 03-14-2012, 08:22 PM   #1
bganso's Avatar
1994 30' Excella
Truckee , California
Rivet Type - Door Strike Plate
The rivets on our door strike plate are loose. This may be a dumb question, but is there a specific type of rivet to use to replace the originals?
bganso is offline   Reply With Quote
Old 03-14-2012, 08:32 PM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Bucked rivets are my guess!
They are most likely bucked rivets placed before the skins were attached to the door frame. You could pull the inside panel(s) off and replace with new bucked rivets or try to peen the existing rivets over to tighten them up. Otherwise, drill them out and replace with Olympic rivets and shave the heads down to look like original rivets. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-14-2012, 09:33 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
They are 3/16 pop rivets. They are original.
Airstream also used them on the pocket in the door for the deadbolt on my Excella. I had to remove that one to run new weatherstrip on the door.
They are available at Home Depot. I think I used 1/2" long ones. (I also have them in 1/4" length, but seem to remember that they were too short)
They are much easier to deal with than bucked or Olympic rivets. All you need is the proper sized drill and a pop riveter.
Vaughan
door handle susans69 All Argosy Trailers 26 05-30-2017 10:23 PM
Anyone know where to find the outside access door hinges? Roothawg Vintage Kin 10 05-13-2012 04:21 PM
banana / belly skin - plastic type Chuck Neir Exterior Restoration Forum 3 03-14-2012 08:13 AM
Door latch broke, after it was closed! frscott Exterior Restoration Forum 2 03-11-2012 01:34 PM
Bath door won't stay shut dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 14 03-09-2012 07:28 AM
