Old 01-13-2008, 07:03 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Rivet question
Starting to work on my doors, the doors appears to be in good shape until I removed the hinges that hold the inner door, the corrosion was so bad
that it created a hole. I'm going to replace the inner door skin and my question is, can I still use the 5/32" Olympic Bulb-Tite Rivets or should go with the type rivet the Airstream installed............thanks
ID:	52491   Click image for larger version
toastie is offline   Reply With Quote
Old 01-13-2008, 07:05 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Toastie,
I believe that it is always preferable to use bucked rivets rather than olympic.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 01-13-2008, 07:09 PM   #3
toastie's Avatar
1955 22' Safari
Originally Posted by wkerfoot
Toastie,
Bill
Do you know where I can buy them, and what kind of tool do I need to install the bucked rivets.............thanks
Old 01-13-2008, 07:09 PM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
bucked are better than olympic if you can do it.
Michelle TAC MT-0
Sarah, Snowball
Old 01-13-2008, 07:20 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Toastie,
Rivets are available at Aircraft Spruce, among others, the air hammer is available at Harbor Freight, among others, you will also need a rivet set of the correct size, bucking bar and clecos. I think that I have everything. Quite a few tools, but a much stronger joint.
There was quite a discussion a short while back about riveting.
It would be worth your time to find someone who could give you a lesson, it only takes a few minutes.
Bill
Old 01-13-2008, 07:45 PM   #6
toastie's Avatar
1955 22' Safari
Toastie,
Bill
Bill
Have the clecos, need a bucking bar, and the air hammer, I'm sure that Aircraft Spruce can help me with the rivet set. What would be a consider a good air hammer.
Steve
Old 01-13-2008, 07:48 PM   #7
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Bill
Steve
Steve,
Harbor Freight has two, one for 4.99 and one for 5.99, currently on sale. I have been told to get one which is adjustable. If they die, you are only out 5 or 6 bucks.
Bill
Old 01-13-2008, 07:52 PM   #8
toastie's Avatar
1955 22' Safari
Steve,
Bill
$6.00 for the air hammer...........
Old 01-13-2008, 07:54 PM   #9
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Yep, normal price 9.99.
Bill
Old 01-13-2008, 07:57 PM   #10
toastie's Avatar
1955 22' Safari
Bill
Bill
Like this Harbor Freight Tools - Quality Tools at the Lowest Prices what tool would I use against the rivet head side?
Steve
Old 01-13-2008, 08:03 PM   #11
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Bill
Steve
Steve,
That is the one, the 4.99 comes with only one chisel. The rivet sets are here: RIVET SETS STRAIGHT .401 SHANK (AN470) from Aircraft Spruce Just make sure that they fit the head of your rivets.
Bill
Old 01-13-2008, 08:13 PM   #12
toastie's Avatar
1955 22' Safari
Steve,
Bill
Bill
Thanks very much for your help, I have a 1955 Safari that I'm restoring. I have the lower interior wall removed, and I noticed that the previous owner replaced a large panel and he used the Olympic rivets, will remove and replace with the bucted rivets. A stronger joint with the bucted rivet would
will make a much stronger total structure...........thanks
Steve
Old 02-20-2008, 06:36 PM   #13
1959 22' Flying Cloud
Escondido , California
What lenght rivets.
Bill & Toastie
I'm replacing the skin portion (interior & exterior) on my door around the lock area and figured while I'm at it I might as well make sure the hinge rivets are okay. What length rivets do you use for the hinge area or the other areas? They come 1/4" to over 1" long.
Also, Since the hinges are stainless steal and the skin is aluminum are we supposed to put something between the two?
Gilbert
2bkidfree is offline   Reply With Quote
Old 04-12-2008, 01:56 PM   #14
2008 31' Classic
Sweet Valley , Pennsylvania
Rivet tool marks on 2007 Classic
While washing the unit today I noticed abou 1/2 dozen rivet marks around the outside of the rivet itself. Looks like it is definately from the tool they used. Will they fix this at JC when I go later this summer? It's clear to me anyway that it was done at assembly. Any feedback would be appreciated
Thanks! Jim
TROPHYJIM2 is offline   Reply With Quote
Rivet and Outerskin question Morning Dew Ribs, Skins & Rivets 11 07-28-2004 09:58 AM
Rivet Question Dennis Clark Ribs, Skins & Rivets 14 05-27-2004 11:11 AM
Rivet Question JMoy Ribs, Skins & Rivets 4 09-27-2003 07:43 AM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
Bellypan Rivet Question Creampuff Our Community 7 01-22-2003 06:42 PM
