Old 06-10-2005, 06:58 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Retrofit Vista View Windows
I am thinking about retrofitting a Vista View Window on my 73 Sovereign which was not manufactured with them. It looks fairly straightforward especially if I do not put in an interior sliding blind as it came from the factory. Before I start chopping holes, I would appreciate any advice.
Marshall in NM
Old 06-10-2005, 07:42 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
If you are getting them form salvage, try to get ones form an Argosy. They are already single pane and will not have the fogging issues that are prevalent in the thermo pane ones.
From what I have heard you can use the new ones that Airstream is installing on the older trailers. It would also make inner trim easier if you use the new inner trim piece since the original ones had a space for the inner shades.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-10-2005, 08:04 PM   #3
till's Avatar
Lisle , Illinois
Images: 108
Marshall,
You are not alone. I am thinking of doing the same thing on my 67. The advantage of a retrofit is that you should not have the leaking issues of windows and seals that are 32 years old. Keep us posted on what you find.
Brett, I never thought about new ones, I may have access to some Vistas that are from a 68. Maybe I will have to check that option out.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
till is offline   Reply With Quote
Old 06-11-2005, 04:25 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Marshall in NM
Marshall,
I see no reason it cannot be done. I have actually had to replace one of mine on my 75 due to broken glass. The factory still makes them for our vintage units. IIRC they run in the $250 each range. But don't cut the holes until you have your hands on the actual window as the sizes differ. They make 2 different sizes of Vista Views that I am aware of. One is approximately 32" long and the other about 10" shorter. I installed mine with Olympics, but if you have the interior panels out you could use bucked rivets for a factory look.
Aaron
WBCCI #XXXX AIR #2495
Vista View window repair/replacement 83Excella Windows & Screens 14 06-06-2013 05:38 AM
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 06:14 AM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 08:23 AM
Vista View Windows On 1979 31' Soverign montanaandy Windows & Screens 14 10-17-2002 05:03 PM
