Old 06-02-2015, 04:52 PM   #1
Ethel1960's Avatar
1961 24' Tradewind
Fort Worth , Texas
Reset gates of Baggage Door key cylinder?
Is there any way to reset the small brass "gates" in these cam-type key cylinders for the baggage door locks on my 1961 Tradewind. (See pics of cylinders and the gates) I'm at a loss if these are salvageable?Click image for larger version
Name:	ImageUploadedByAirstream Forums1433285553.087794.jpg
Ethel1960 is offline   Reply With Quote
Old 06-02-2015, 05:09 PM   #2
Ethel1960's Avatar
1961 24' Tradewind
Fort Worth , Texas
And yes I did pull the keys out before I installed it in the main housing.
Old 06-02-2015, 05:39 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Take the whole thing to a locksmith. They may even be able to key it to match another of your trailer keys.
"Warning: If you take the key out of the Cylinder before you install it in the lock deelind Doors & Locks 10 12-14-2014 05:46 PM
Replacing key cylinder for Bargman L-77 mello mike Doors & Locks 18 02-27-2012 01:10 PM
1984 EXCELLA Cylinder and key replacement Ackatak Doors & Locks 0 11-05-2010 08:50 AM
1953 Baggage Door Lock pinktrailer Exterior Storage Compartments & Access Doors 15 10-22-2010 02:15 PM
Busted the black plastic handle off one of my dump valve gates wacnstac Waste Systems, Tanks & Totes 7 08-07-2006 09:23 AM
