Old 10-28-2013, 11:37 AM   #1
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
Replica Bargman L-100 DEFECT
i believe there is a defect in the reproduction Bargman L100. After spending many hours on this, and reading other threads (https://www.airforums.com/forums/f45...ir-100171.html) , . Vintage trailer supply offered no help, aside from "take it to the locksmith if turning the screw doesn't work". In the following photos ill show you why i think it's a defect.
This lockset was installed new, out of the box and failed on our first trip. it spent the last 2 years in a box after having to buy a second L 100 from VTS in 2010. that one has held up.
this is what the inside of the exterior handle should look like all the time :
But because of a lose handle, that center square with a screw in it doesn't sit all the way into the cam's square hole ... see how it looks below, when i am not holding the handle 'pushed in'... so the cam falls off after i left go of the handle because the handle slips out just enough so that the cam is only 1/2 way on the square piece of the handle.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 10-28-2013, 09:15 PM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I am a locksmith. Can you post a picture of the lock with the screw out? I need to see behind it.
Skatiero is offline   Reply With Quote
Old 10-29-2013, 04:38 AM   #3
Baltimore , Maryland
I posted about this on my blog. It is a serious problem and has resulted in numerous clients getting locked out of their trailers. When it happened to me, it prompted me to write about it. I would post a link but that violates a term of service and I do not want my hand slapped again. Just yesterday I had a client swing through because of this issue.
Old 10-29-2013, 05:29 AM   #4
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I can see what's going on a bit but it's hard with it not all apart. If someone wants to send it to me I will figure it out and post my findings and send it back and of course repair it to the best of my abilities. If you have the keys that would save me some work.
Rob
Old 10-29-2013, 05:41 AM   #5
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Washer install?
I've seen a thin washer installed to hold these parts together.
Mike
desertair27 is offline   Reply With Quote
